I'm developing my bootloader based on AN1388. My bootloader is working pretty well.
I'm having problem with my app code. When I try to generate the hex code, seems there isn't "C startup code". My .map file says kseg0_boot_mem used is 0.
So I've tried to compile the demo app that came together with AN1388 "as is". It happens the same. But the pre-compiled hex in this example is correct. It has the kseg0_boot_mem in the hex.
So, anyone knows what I'm doing wrong?
Edit:
I'm using C32 v2.00 and the AN1388 was compiled with C32 v1.11.
  • \$\begingroup\$ I can't remember the specifics (haven't used a PIC32 with C32 for a little while) but have you got the linker script set up correctly? The startup code is probably referencing the C018.o file IIRC. \$\endgroup\$ – Oli Glaser Sep 14 '11 at 16:01
  • \$\begingroup\$ Are you getting a linker or compiler error? What exactly is the error if you are getting one? \$\endgroup\$ – mjh2007 Sep 14 '11 at 19:08
In MPLAB IDE check your build options -> directories to make sure that the Library Search path is set correctly. I believe this directory is where the linker loads the C startup code from.
