How can I generate a inverted signal of a 20MHz Clock signal synchronous to the original signal? (At least, very close to the original)
With a typical HEX INVERTER the propagation delay is already too high (5-10ns).
Should I use a single-ended to differential IC? Couldn't find any references on the internet.
