I've created 3 or gates in an electric circuit with transistors (bipolair npn). I've tested 3 OR gates. with no transistors, with 1 transistor (the same as no, but the output is going to a single transistors base), and with 2 transistors. I've checked the output with an LED. All OR gates give the right output. After that I've created 3 XOR gates, an NAND gate and an OR gate ging into an AND gate. Switch A goes into input 1 in the NAND and the OR and switch B goes into input 2 in the NAND and OR gate. Only the XOR gate with the 2 transistor OR gate works but I have no idea why the others don't work. any help?
I'm using a breadboard with a 5V DC source with a max of 2.1A (phone charger)
Solution: if A is true and B isn't, current can flow to a transistor of the nand gate.
