My question is related to my previous question:Accuracy of a data acquisition hardware
In a data acquisition system absolute accuracy is defined as measure of all error sources as following:
Abs. accuracy = error from Gain(Span error) + error from Offset + (error from Noise + Quantization)
Here in the following data sheet at page 30 and 31:
http://www.mccdaq.com/pdfs/manuals/PCI-DAS6034-35-36.pdf
"absoulte accuracy" is defined.
My question is about interpreting these parameters.
Lets say I take five samples by applying precisely known 5V reference voltages to a channel as:
I apply 5V and daq-board reads 5.004V
I apply 5V and daq-board reads 5.002V
I apply 5V and daq-board reads 5.001V
I apply 5V and daq-board reads 5.003V
Now the readings above are different than the 5V true value applied.
So the readings above includes gain error + offset error + noise error
Noise error is statistical in nature and wont effect the mean value but the disperse.
As far as I understand, What effects the mean value here is the "gain error" and the "offset error" (systematic errors).
My question is: Are the gain and offset errors in the data-sheet fixed values or are they maximum values and also statistical or indicate a range?
For example, if data sheet says offset error is x, and my mean reading is A; should then I correct my reading as A-x ? or x is not constant?
I'm asking because if lets say offset error is fixed and knwon for all measurements why don't they compensate it before sending the data to sthe erial port instead of documenting?
Or if it is not fixed should I measure offset before each measurement?
