How to find out Processor one GPIO pin maximum source current and maximum sink current? In datasheet mentioned IoL and IoH, is it same for GPIO source and sink current also?
  • \$\begingroup\$ Can you give us the datasheet? \$\endgroup\$
    – Greg d'Eon
    Commented Oct 14, 2015 at 12:57
  • \$\begingroup\$ Its a IMX6 solo Free scale processor \$\endgroup\$
    – Ram_HW
    Commented Oct 14, 2015 at 12:59
  • \$\begingroup\$ cache.freescale.com/files/32bit/doc/data_sheet/IMX6SDLAEC.pdf \$\endgroup\$
    – Ram_HW
    Commented Oct 14, 2015 at 13:00
  • \$\begingroup\$ I can't find it either, looking at the datasheet on page 39. Looks like a hard current limit is not specified, but the Vih/Vil was tested using 1mA when register ipp_dse >= 3, so 1mA is a safe value. If you need 2-3mA it's probably ok as long as you aren't running hot. \$\endgroup\$
    – Justin
    Commented Oct 14, 2015 at 13:45
  • \$\begingroup\$ yes you are correct , i also try to find in datasheet but its not clearly mentioned. I am going to send mail to Free scale. thank you very much for your time to help me. \$\endgroup\$
    – Ram_HW
    Commented Oct 14, 2015 at 13:49
That is one of the most useless datasheets I have ever seen.
The maximum current levels for GPIO pins are not specified in the data sheet. This apparently is intentional on Freescale's part.
This question was brought up in a Freescale forum. A Freescale employee, Yuri Muhin answered. In the last paragraph, he says "Maximum current levels ... are not specified."
Here is the full text of his answer:
Re: Source and Sink Current on i.MX6 SoloLite Yuri Muhin Employee Yuri Muhin Apr 14, 2014 1:02 AM (in response to David Boling)
There are values of load current in the Datasheet(s), which relate to some typical configurations, in particular - in order to guarantee specified output voltages. For more accurate (application depended) estimations IBIS models should be applied.
Really the data of i.MX Datasheets specify maximum / minimum voltage levels in relation with current loads. These current values should not be considered as maximum allowed ones, just as reasonable. IBIS model provides current-voltage curves for pins in order to calculate real currents and voltages on pins.
Another case, that corresponding voltage (high, low) levels may not be in ranges, shown in Datasheet and defined as logical 0 or 1.
Maximum current values (which do not decrease life time and do not damage the device) are not specified, because they are application dependent and relate to general thermal estimations. Say, if a separate pin can sink high current, say greater than 8 mA, this does not mean that all pins may be loaded (simultaneously) with such values. Strictly speaking the i.MX6 is not intended to be used as high current GPIO source or sink, assuming that special buffers or I/O expanders should be applied for it.
Have a great day, Yuri
Have a great day, indeed.
