I'm making a 2S1P battery pack with 18650 elements, each of which is protected. Cells currently can be charged individually as each has a TP4056 board attached to it, that means charging one cell then another and so on. However, I have a balancing charger that supports charging 2S packs, with a 3-wire output. Can I just attach the balancing leads to the cells' protedted output connectors? Will the protection circuits somehow disturb the operation of balance charger?
\$\begingroup\$ Hmm, +1 for interesting question. In this case I would hook it up and hope it doesn't blow up. \$\endgroup\$– DanielOct 15, 2015 at 1:11
\$\begingroup\$ But I would monitor the temperature and voltages and shut it of before things went nuts. Also, make sure you don't ground one of the Balanced wires \$\endgroup\$– DanielOct 15, 2015 at 1:12
1 Answer
Can your 2s charger not charge in normal or 'unbalanced' mode with the 3 wire balance connector not connected? Almost all chargers do.
So why balance charge your 2s battery? The TP4056 chips should ensure that they each charge to the correct 4.2 volts and therefore will be balanced. Or will th TP4056 not work when charging in series?
Even if you connect the balance wires, it should work. All the balance wires do is measure the voltage and then at the end, or near the end of the charge, bleed small current from the higher voltage cell and then recharge the battery up to 8.4v. So can you discharge a small current (usually less than 300mA) from the TP4056 connector? If so, then I believe that it should work. If the TP4056 connector doesnt allow you to measure the cell voltage, then the charger won't even start.
However, I have no experience with the TP4056 so watch it closely if you decide to go ahead!
