I am following a tutorial on programming baseline 12F series PICs in assembler.
I have a question regarding bitwise operators specifically the << left shift operator.
Lets use an example the PIC I'm using is a 12F509 so if I wanted to set GP1 and GP0 as outputs and the rest of the I/O pins as inputs I would normally do it like this.
movlw b'111100' ; Set GP1 and GP0 as outputs
tris GPIO
If I wanted to use a bitwise operator to achieve the same thing I think I could use << left shift like this.
movlw 0<<1 ; Shift 0 left once to set GP1 and GP0 as outputs
tris GPIO
I take it after this operation the last 2 bits would be 00. Since << left shift shifts all the bits to the left discards the leftmost bit and sets the bit to the right to 0.
This is my understanding of how the bit shift left operator works. Hopefully it's correct.
Now in the tutorial this bit of code was introduced there was an explanation of what it does but not how it does it.
movlw ~(1<<1) ; set GP1 as an output
tris GPIO
I'm going to take a stab at what this code is doing let me know if I've got it right. It's first shifting a binary 1 left once into the GP1 position which leaves a 0 in the GP0 position.
So when the operation in the parenthesis is complete the value would look like this 000010.
Then the ~ is inverting the 1 in the GP1 position to 0 and the 0 in all of the other positions to 1? Leaving the value set to 111101 (GP1 as an output)?
Thanks In Advance.
movlw 0<<1
sets theW
register to be 0x00.tris GPIO
then sets the GPIO TRIS register to have the value fromW
. So that would be all-0's, not just 0 in the lsb. So that would set all the pins on the GPIO port as outputs. \$\endgroup\$
