-3
I have an LCD module (from a mobile phone) with unknown pins. It has 40 pins and is labelled with this number: "TP-Y0100-c0".
Can anybody help me to identify the pins? I want to use it with microcontroller
closed as off-topic by Leon Heller, Brian Carlton, PeterJ, Fizz, nidhin Oct 18 '15 at 4:36
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions on the use of electronic devices are off-topic as this site is intended specifically for questions on electronics design." – Leon Heller, Brian Carlton, nidhin
If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ Maybe a photo of the module in question. You might have more luck searching on the phone model and seeing if other hackers have used parts from it. You might have to simply reverse-engineer the pins as best you can. \$\endgroup\$ – user65586 Oct 17 '15 at 19:07
Random LCDs are notoriously hard to reverse engineer, and not worth it unless you have a stack of 10,000 of them. Consider using a more common part with lots of support, like a Nokia 5110, 1602 LCD, or one of the many modules that are brought up with a quick search on eBay. These are dirt cheap, have pre-written drivers, and are going to actually work.
If you're dead set on reverse engineering it, I would start here http://www.eevblog.com/forum/projects/reverse-engineering-lcd-from-ipod-nano-v6/ to learn what you're up against.
