Just trying to switch a relay when a comparator goes high with a transistor but the comparator outputs 1.3v when 'low' which is enough to set the transistor.
Using a 741 opamp as the comparator with a zener diode as one input and a pot providing the source for the other input. Positive rail is approximately 13v while the negative is 0v. Obviously the positive side of the relay is connected to power, just isn't shown in the schematic below.
Is there a good way an easy way to fix this or should I be looking to use another chip with lower output?
Thanks! enter image description here
  • \$\begingroup\$ LM741 makes a crappy comparator. LM393 is dirt cheap as well and works much better in this situation. It has open collector output (very easy to attach PNP power transistor). \$\endgroup\$ – venny Oct 18 '15 at 13:33
  • \$\begingroup\$ Thanks, I'll be sure to look into it next time I need one \$\endgroup\$ – Eddy Oct 19 '15 at 9:42
You could just add a resistor divider:
Also, have you tried it or is this just your calculation? Because, if you try it, it might still work, as the transistor might help pull down the output stage below the limit it has while sinking current.
| improve this answer | |
  • \$\begingroup\$ I did try that actually. Brought the voltage down to about 50mV without the transistor connected, but once it was reconnected it increased to 0.55v. Which didn't make all that much sense to me. \$\endgroup\$ – Eddy Oct 18 '15 at 11:21
    \$\begingroup\$ Then you may have just used a too large division factor? The values I suggested should work. Also, 0.55 V after the resistor might not be incorrect - because, that may be the region where current starts flowing into its base. Have you tried switching the relay that way? If it still does not work, decrease the values of R1 and R2 with the same factor, i. e. set R1 to 1.2 kOhm and R2 to 400 Ohm. \$\endgroup\$ – J A Oct 18 '15 at 11:23
  • \$\begingroup\$ Yep, ended up being my division factor must've been too large. Tried 10k and 3k and now it works as expected. Thanks for that! \$\endgroup\$ – Eddy Oct 18 '15 at 11:38
