I calculated the breakaway points. They come out to be
Root 1: -2.481
Root 2: -0.689
Root 3: 1.17
because of root locus properties only the -2.481 will fall on root locus . But when I saw the solution there were no going towards breakaway points. I just want to know when to calculate the breakaway points.
A breakaway point can only occur between two adjacent real open-loop poles. A break-in point can only occur between two adjacent real open-loop zeroes.
A real solution to \$\frac{dK}{ds}=0\$ is not a sufficient condition to establish the existence of a breakaway or break-in point.
To find all the points with multiple roots you need to solve the two equations: $$c=0$$ and $$\frac{\partial c}{\partial s}=0$$ where c is the characteristic equation. Then choose those solutions whose \$K\$ values are in the domain of interest.
The break-away and break-in points are a subset of the above solutions, and are those whose s values are real.
So in your example, the two equations are: $$K (s+2)+(s+3) \left(s^2+2 s+2\right)=0$$ and $$K+s^2+2 s+(s+3) (2 s+2)+2=0$$ and the solutions are:
So you have no break-away or break-in points if \$K>0\$, and one such point if \$K\$ can also take the value of \$-1.90665\$.
  • \$\begingroup\$ how you calculated $K+s^2+2 s+(s+3) (2 s+2)+2=0$ for K how can you solve it \$\endgroup\$ – Boris Oct 19 '15 at 14:39
  • \$\begingroup\$ I solved the two equations simultaneously for K and s (using Mathematica). \$\endgroup\$ – Suba Thomas Oct 19 '15 at 14:46
