I would like to start programming PIC12F683 but I have no clue how to handle I/O. Where can I find specific syntax for specific controller?
I have tried to register on their forum, but I have't received e-mail (resent registration email multiple times, no luck).
I have found programming guide on their site - PIC12F6XX/16F6XX Memory Programming Specification - http://ww1.microchip.com/downloads/en/DeviceDoc/52053B.pdf If required information is there, then I have some trouble to find what I want.
Might be there is related articles, step by step guides, videos?
closed as too broad by Matt Young, Nick Alexeev Oct 20 '15 at 18:12
Please edit the question to limit it to a specific problem with enough detail to identify an adequate answer. Avoid asking multiple distinct questions at once. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ ANSEL=0x00; TRISIO=0x00; while(1) GPIO=~GPIO; Nothing magical about that. Everything is in the skinny 176-page datasheet. \$\endgroup\$ – venny Oct 20 '15 at 17:24
  • \$\begingroup\$ When the question was closed, I was in the process of writing up an answer with some links to tutorials. Here's one, for the PIC12F675 which is almost identical to what you are using. \$\endgroup\$ – tcrosley Oct 20 '15 at 18:22
Go to product page and click 'Documentation& Software" button. You will end up here -> http://www.microchip.com/wwwproducts/Devices.aspx?product=PIC12F683#documentation . Take a look at application notes; the majority of them contain source code in the zip file with explanation of the code given in pdf. This is the fastest way to learn application of PIC peripherals.
