I have very basic knowledge of electronics.
I am looking for a circuit which can turn ON/OFF an LED from a single switch.
  • If the LED is OFF and the switch is pressed (even if not released) then the LED should turn ON.
  • If the LED is ON and the switch is pressed (even if not released) then the LED should turn OFF.
A switch can be a push to ON switch but turns OFF when released. It is not like a toggle switch.
Thanks in advance
  • \$\begingroup\$ What parts are available to you? Would a D-Flip Flop work? \$\endgroup\$
    – Tyler
    Oct 21, 2015 at 2:29
  • \$\begingroup\$ Hi Tyler, I have 555 timer IC but can get other items as well. Just need a really simple solution to achieve this. \$\endgroup\$
    – Amit Kumar
    Oct 21, 2015 at 2:34
    \$\begingroup\$ Your solution is right here. It's called a "Soft Latching" power switch. Check it out \$\endgroup\$
    – ezra_vdj
    Oct 21, 2015 at 4:12
  • \$\begingroup\$ @ezra_vdj If the button is not released then the circuit will oscillate; the LED will flash. \$\endgroup\$ Oct 21, 2015 at 11:35
  • \$\begingroup\$ @CharlieHanson If it's good enough for Dave Jones I'd say it's good enough. All depends on project, cost, who's using it etc though, you feel? \$\endgroup\$
    – ezra_vdj
    Oct 21, 2015 at 11:41
This one is fairly simple: -
Each time you press the button, the output latches in the opposite sense to what it previously was. Lots of good ideas.
Picture stolen from this stack exchange question: Make a Latching Relay using SPDT Relays
Is this question all but identical?
  • \$\begingroup\$ Thanks Andy. The circuit looks OK but will not fit my project as I have to manage multiple LEDs. May be 10 or something. Do you have any suggestion? \$\endgroup\$
    – Amit Kumar
    Oct 21, 2015 at 23:34
  • \$\begingroup\$ Here is my exact requirement. electronics.stackexchange.com/questions/196598/… \$\endgroup\$
    – Amit Kumar
    Oct 22, 2015 at 0:09
  • \$\begingroup\$ I have answered this question for a single channel. Just step and repeat for multiple channels. I don't see the problem unless, of course, you have changed your mind about what you want. \$\endgroup\$
    Oct 22, 2015 at 9:21
  • \$\begingroup\$ I haven't changed my mind. I was looking for a circuit with less number of components. However, your answer seems to be more accurate than others. Thanks for your help. \$\endgroup\$
    – Amit Kumar
    Oct 22, 2015 at 23:26
