For example, if you were to put 5V across a \$150\Omega\$ resistor and measure its resistance with a multimeter, the reading would always be a few percent off the true value. What reasons might there be for this inaccuracy?
    \$\begingroup\$ When measuring resistance you have to unplug the source. The MM uses current/voltage for resistance measurement \$\endgroup\$ – Sider Oct 21 '15 at 17:23
    \$\begingroup\$ I am not sure, so sorry if this is a basic suggestion, but are you familiar with the fact that all resistors have a specified tolerance? Most designs can get away with a resistance of +- certain percentage. You only go for tight tolerances when the need arises. \$\endgroup\$ – Jarrod Christman Oct 21 '15 at 17:24
  • \$\begingroup\$ Minor tip: '5 V' not '5 Vs' which would be read as volt-seconds. \$\endgroup\$ – Transistor Oct 21 '15 at 18:47
    \$\begingroup\$ The multimeter and its leads also contribute errors to your reading. The total error that you measure should be within the limits of (meter accuracy) + (resistor tolerance). \$\endgroup\$ – Dwayne Reid Oct 21 '15 at 19:11
    \$\begingroup\$ Please note that editing your question title to read "[SOLVED]" is not appropriate at StackExchange sites. Instead you should click on the check mark to the left of the answer that you consider best solves your problem. \$\endgroup\$ – Oleksandr R. Oct 21 '15 at 22:21
The resistor may have a 1% or 2% tolerance (5% resistors used to exist, but are pretty rare these days, at least for professional suppliers).
Then check the specification of your meter. I would be surprised to find it had a better accuracy than 2% unless it was a really expensive one.
These tolerances can add up worst case, to give you 3% to 4% error, with meter and resistor fully inside specification.
When measuring resistance, it is generally good to disconnect it entirely from any circuit. In this way, the multimeter isn't measuring the resistance of the circuit, but is only measuring the resistance of your resistor.
The connection between probes has a finite resistance that needs to be zeroed out. Touch your probes together to see if you get zero volts. If you don't, some meters have a way to zero this out, or you can do it in your head.
At 150 ohms, 3 or 4 ohms in series in the probes/meter is a significant percentage.
Of course, you need to remove the resistor from the circuit for accurate measurement. If you are measuring HIGH resistances, you also can't hold the ends of the resistor in your hand, as your body impedance in parallel can impact the measurement.
The multimeter itself is actually correct because all resistors have a tolerance (so the resistance of the resistor could be +/- a certain percentage).
The multimeter measures much more accurately and gives you the real value of the resistor.
You can get more accurate resistors if you need however for simple, 'normal' uses, a normal resistor with a 1%-5% tolerance should be fine.
Commercially available resistors will typically be 5% or 1% tolerance, which means that within their operating temperature range, they will deviate no more than that much from their nominal value.
When you put some voltage across a resistor, it will conduct current and start dissipating some heat. This will cause a change in temperature, which will in turn change the actual resistance, but should still keep it in tolerance range.
On a side note, Your multimeter's manual suggests to remove components from circuit board while measuring their attributes. If a component is within a powered circuit and you attempt to measure resistance/capacitance/hFe etc, it may give widely incorrect readings, and may also kill your multimeter.
