8
The normal musical instrument pickup uses a magnet inside a coil, and the movement of a ferromagnetic string causes changes in the magnetic field, which then induce currents in the coil.
Another possibility would be to use just a strong magnet near a string, and measuring induced currents in the string itself. This would only require a conductive string, not a ferromagnetic one.
Does anyone actually use this method? Is there a name for it, or is it useless, so no one talks about it? I tried it last night, and it works, but the signal is very low (-50 dBV, for instance, vs -5 dBV for a magnetic electric guitar pickup).
  • \$\begingroup\$ Just came across this again, and had a thought: A third possibility would be to use an isolated current source to pass a current through the string and generate a magnetic field. This would allow for non-ferromagnetic strings, and higher currents could generate much stronger signals than a static string, but would retain the coil pickup advantages. \$\endgroup\$ Commented May 2, 2012 at 17:40
  • \$\begingroup\$ @KevinVermeer: The pickups would have to be rotated 90° from their normal position, right? With their axis perpendicular to the string \$\endgroup\$
    – endolith
    Commented May 2, 2012 at 19:08
  • \$\begingroup\$ Good point. I'm having a hard time figuring out where the magnetic field would go (and looking like a fool twisting my thumbs in various directions and tilting my head), but it seems like this would produce little variation in the magnetic field when the string moves. \$\endgroup\$ Commented May 2, 2012 at 19:55
  • \$\begingroup\$ @KevinVermeer: It would definitely produce variations, with the field becoming weaker and stronger as the string moves closer and further from the pickup. \$\endgroup\$
    – endolith
    Commented May 2, 2012 at 20:39
  • \$\begingroup\$ Right, but IIRC the string motion is parallel to the plane of the guitar. A normal pickup doesn't care, but this could produce a different volume if the string was slapped (as in a bass guitar) rather than plucked, and the volume would change if the oscillation wasn't in a constant plane...it could be interesting. Let's take this to chat if you want to talk about it more, though I won't have time today. \$\endgroup\$ Commented May 2, 2012 at 21:13
4 Answers 4
11
For stringed instruments, no, but the principle is used in many, many places.
It's not useless, but it has some significant disadvantages, and other methods are simply far superior.
I tried it last night, and it works, but the signal is very low.
That is the main disadvantage. Others are:
  • You are measuring low induced voltages in the string that is in contact with a conductor (human) which messes up the measurement
  • More advanced measuring techniques induce a voltage in the string, but again the human conductor is in the way
  • The strings are more variable in terms of electrical properties (resistance, capacitance, inductance) all of which affect the sound, and mean that two instruments might sound very different
  • The strings, being long, are not unlike antennas and inductors and are very good at picking up stray noise in electrical and magnetic fields. You can be much closer to a lamp ballast with a coil pickup before picking up the AC hum than you can with a string pickup.
  • There's no galvanic isolation, so the amp has to be isolated from the AC line and high voltage sources, which pretty much rules out tube based amps.
  • Electrostatic discharge from the user into the string and conducted into the equipment is damaging, but even if it's suppressed you can't easily filter out the additional noise it causes.
  • Getting a good electrical connection to the string in a performance environment is difficult since it's hard to tin the metals used in many strings, and vibration, corrosion, and other environmental factors complicate it.
That's just the start. Don't misunderstand, coil pickups have disadvantages too, but they are superior in many areas.
Yes, this method IS in use and has been for quite some time. stringamp.com is a Danish company that uses the technique and carried the design forward, after another company went under (in the 1930s, I believe).
They have multiple leads from the instrument, to a belt-hung controller/pre-amp (6 controls for a 4 string violin), which I presume to be 4 tone controls and a balancing volume between the top and bottom pairs of strings (Presumption based on conventional 2-pickup, 3-potentiometer controls of 2-pickup guitars).
  • \$\begingroup\$ +1 for finding a use of this method. I'm not sure about the tone controls part, since the idea is just to reproduce the sound as faithfully as possible - I imagine any tone/effects are intended to be added later. I think the system just provides a preamp for each string and this is mixed into an output signal. If you look at the preamp box it seems there is just a trim pot for each string, input on left and output on right. \$\endgroup\$
    – Oli Glaser
    Commented Sep 24, 2012 at 8:08
  • \$\begingroup\$ I don't see anything on that page about how the system works, other than "The StringAmp™ works by the spatial movement of the string in an individually calibrated active field. The preamplifier is very special, in both generating and sensing this field." \$\endgroup\$
    – endolith
    Commented Sep 24, 2012 at 15:38
Moving coil and moving magnet phonograph cartridges (and other similar transducers) embody essentially the same principles as what you are describing. As you would expect from your experiments, moving coil cartridges have a much lower output than moving magnet. However, the fidelity is presumably better with moving coil cartridges.
If you can get an acceptable signal to noise ratio, I don't see any reason why this wouldn't work. I would expect the timbre to be somewhat different, however. You will most likely need an additional 10 to 20 db of voltage gain. You might (carefully) try a high-impedance microphone input, or placing an op-amp in the signal path to get a bit more gain.
Given the eclectic nature and history of pickup coils (such as humbuckers) and the demands put on musical instruments by the stage environment, I would characterize your application as a "specialized use." There's no way to know ahead of time if the strings will be more sensitive to feedback, for example, without testing it first.
I once put a condenser microphone on a pillow, set an autoharp on top of it, and cranked up the treble. The resulting recording was awesome. Keep experimenting!
  • \$\begingroup\$ I would expect a moving coil cartridge to have a higher output than a moving magnet, given identical coils and magnets, since the coil has less mass. \$\endgroup\$
    – endolith
    Commented Mar 24, 2010 at 13:55
    \$\begingroup\$ From Wikipedia: "A disadvantage however is that moving-coil cartridges generate an even lower voltage signal than a moving-magnet type cartridge. This is because the moving coil cannot be large enough (it would be too heavy) to generate equivalent voltage levels. The resulting signal is only a few hundred microvolts, and thus more easily swamped by noise, induced hum, etc." \$\endgroup\$ Commented Mar 24, 2010 at 14:47
See this link for details on using a moving string as a pickup. http://music-electronics-forum.com/t14952-2/
The most practicle way is to use an 8 ohm to 20K ohm or higher miniature transformer (8 ohm side) attached across a string behind the nut and the bridge. The string acts like the ribbon in a ribbon microphone.
Attach the high impedance side of the transformer to the amp input. Also, attach one leg of the low impedance side to the high impedance ground side to minimize noise.
Place one or more magnets in the space between the neck and the bridge and listen for tonal changes as the magnet position is changed.
You can also pass a string or strings through miniatute toroid current transformers to obtain sound from each independent string or the combined strings.
Transformers are the most practicle way to boost the very low impedance of a guitar string in the .5 to 1 ohm range up to a higher more useable level without introducing too much noise.
The sound quality with this setup can be more acoustic sounding than the traditional sound of a high impedance guitar pickup that all have a resonant hump in the 2Khz to 5Khz range.
