-4
Using standard headphones, is it possible to connect it to a standard non-VOIP wired phone? What connector would I need, or how could I rewire this?
Headphones have some kind of 3.5 mm jack, Phone handsets have 4 wires BRGY going into a jack. But that's all I understand.
The first step in researching this kind of project is to look for the pinout.
Then you can check what a common headset plug might be (there are different pinouts, you'll need to test yours, especially for an Apple product):
Then you might think, someone must have done this before, so you google the final product and get this kind of thing:
So, you can build it by buying the proper 2.5mm female jack and wiring it in to the handset plug, or you can buy the finished product for around $15.
  • \$\begingroup\$ Except the position of mic ring and ground can be swapped on some products forums.windowscentral.com/windows-phone-8-how-guides/… \$\endgroup\$ – Fizz Oct 24 '15 at 1:51
  • \$\begingroup\$ @RespawnedFluff It's not an exception to what I said, because what I said was "there are different pinouts, you'll need to test yours". \$\endgroup\$ – Samuel Oct 26 '15 at 17:26
  • \$\begingroup\$ Indeed. Alas, I've only skimmed what you wrote, expecting to see the two usual configs in the diagram, not just one. \$\endgroup\$ – Fizz Oct 26 '15 at 17:36
