9
I am currently using Atmel Studio 7 and I need to enable c++11 support for it. I couldn't find any documentation about this topic. Moreover, I am not even sure it has c++11 support, yet.
    \$\begingroup\$ Have never tried it but does it work if you go into the AVR/GNU C Compiler / Miscellaneous options for the project and change -std=gnu99 to -std=gnu++11? \$\endgroup\$
    – PeterJ
    Oct 24 '15 at 10:31
    \$\begingroup\$ An alternative I am using is setting the compiler flag -std=c++11. You can write this or PeterJs solution in the "Other flags field of Miscelleaneous of AVR/GNU C++ Compiler. \$\endgroup\$
    – Grebu
    Oct 24 '15 at 13:32
8
I just started a new C++ project under Atmel Studio 7 and with the default options the following code failed with a nullptr not declared error:
char *c;
if (c == nullptr)
Then I went into the Toolchain options under the project properties and added the -std=c++11 flag as suggested by Grebu under the "other flags" which seemed like the best place for it and it compiled fine:
Atmel Studio with C++ 11 enabled
