If I have a PCB with standard 1.4 mil copper thickness. I have used a trace width calculator based on IPC-2221 to determine that a 2.72mm trace is enough to handle 5 amps for an "external layer in air".
I have seen many times on power supply and relay board that people add solder to unmasked traces to increase the safe current flow.
I am using Sn63Pb37 solder. My finish is ENIG. I know that solder is much less conductive than copper.
My question is how much does this help? If I lay a fat convex blob of solder over the entire length of the track what ballpark level of increase in safe current flow can I expect?
I am sure an exact answer relies on various circumstances but a conservative value would be helpful.
I have seen in various claims on the internet that it can increase the amount of safe current by 40%-100%, but the sources seem to contradict each other. I would like to get an educated answer.
Is there any reason why doing this is a bad idea?
[EDIT]
I am going to attempt to answer this myself based on the information at PCB Tinning to increase current about how to figure out conductivity based on cross section and KalleMP's information about solder conductivity. Please correct me if I get any of this wrong.
Assuming a 1.4 mil thick copper trace with a width of 1 mm(to make the math simple) and a convex layer of solder going .5 mm tall at the highest point.
The cross section of the trace is a rectangle 1 mm wide by 1.4 mils(0.03556 mm) tall which gives an area of 0.03556 mm2.
Assuming a circular shape a 1mm wide and .5mm tall blob's cross section is a half circle so I use pi * .5^2/2 to get an area of about 0.3927 mm2.
If I go my what KalleMP said about solder being about 9-14% the conductivity of copper I can conclude that the effectiveness of the solder should be the equivalent of 0.035343-0.054978 mm2 of copper which is a 99-154% improvement, less depending on how thick the solder blob is.
This answer seems consistent with some of what I have heard from others, but I have also read of people doing actual tests and finding it closer to 40%. Does anyone see any fault in my reasoning? Are there other factors that would reduce the improvement such as the connection between the solder and copper?
[Note] at first I posted a different solution with an error, I think I have it right now.
