-2
I'm working on pic24fj128ga202 microcontroller. My pic is interfaced with eeprom via I2C. I can't write and read on eeprom(BR24G256), then I read the datasheet of eeprom and came to know that there is a write protection for eeprom. I googled it for pic24f, i can't get any solution. So i searched for other pic series i got some suggestions related to code. The code i got is
#pragma config WRTD = OFF    //Disable EEPROM write protection
I refer the my pic24f datasheet, i can't see WRTD. Other than this suggestion will work it in MPLAB seetings?
My IDE is MPLABv8.92 and using PICkit3 programmer.
Thanks...
    \$\begingroup\$ Why would you use a PIC-internal solution for an external EEPROM? \$\endgroup\$ – Ignacio Vazquez-Abrams Oct 25 '15 at 9:24
The PIC24 does not contain EEPROM, so the 'setting' you found does nothing.
The write protection is on the BR24G256 chip itself. Likely WP pin 7 on the BR24G256 device is tied high, enabling the write protection.
Additionally, if you can't read from the EEPROM it suggests another issue. Write-protect only disables write actions, but you should be able to read the contents.
| improve this answer | |
  • \$\begingroup\$ Hi @Hans Thanks for the reply. Sorry i didnt mentioned. My EEPROM is tied with GND. \$\endgroup\$ – user6161 Oct 25 '15 at 10:22
