What are throughput and speed limiting factors in an ethernet or any other type of cable which is used for data transmission?
  • \$\begingroup\$ This question is rather broad and the answer depends on how much theory you already know; but the short answer is "Shannon-Harley theorem" also known as the "Shannon limit". \$\endgroup\$ – pjc50 Oct 26 '15 at 13:57
  • \$\begingroup\$ @pjc50 - I assume you mean Shannon–HarTley theorem. Maybe upgrade that, with an explanation, to an answer? \$\endgroup\$ – gbulmer Oct 26 '15 at 16:32
See this article: -
Taken from here and note that it doesn't just apply to coaxial cable - skin effect and dielectric losses are a real problem for all cables wishing to relay signals at high frequencies.
| improve this answer | |
