I made a custom library for a 1x3 header with 5mm pitch on Cadsoft Eagle. Since I had to make the pins in metric, I'm having an issue now connected to the 0.1 inch grid that the rest of my schematic is in.
Picture 1 - It's two pictures combined. Top picture shows the pin and ground, bottom shows that they don't match up "exactly" on the grid.
After scurring around on the web some, I found several posts generic posts saying to just change the grid to a very small size (0.001/0.0001 inch) to make a bunch of connections then throw a Junction over top and it will work out fine. If I do this, then the ERC will have many more errors about overlapping.
Unfortunately, after looking at the ERC Errors, it still says it's not connected.
Notes:
The ground is only so close that the junction is covering so I could get a good close picture. In reality, I would move it to the right more.
I took pictures after saving and restarting Eagle. I know that can be problematic at times also. I'm also using Net's, not wire.
My questions:
Will using a tiny grid and having a Junction still count/pass as a connection when I go to have the PCB made? I know the ERC can be sketchy at times. I have the same issue with Pin 2 but used the grid change/Junction method also.
I made the part library using 5mm to inch conversion, then placed the pins at (-0.19685 0), (0 0), (0.19685 0 ) so they were technically placed on the inches graph. Is changing the grid to 0.19685 then connecting the net's an effective solution?
Is there a proper way to make metric components to fit on the 0.1 inch grid? I know it's a general rule to keep the 0.1 inch grid.
I've read/seen Youtube video's that says to take the ERC with a grain of salt. Should it be taken "seriously"? IE correct all of the errors?
