I am looking for a way to use a MOSFET as a normally closed switch such that when a battery charger is attached it opens the switch to disconnect the battery from the rest of the circuit. I want the load to be between the MOSFET source and ground, instead of between the battery and the MOSFET drain.
EDIT: I want the load of the battery to be disconnected. Thus the battery is only connected to the charger. The battery is a single cell LiPo and the charger will be built into the board so just charging power is needed to charge the battery.
