I'm creating some footprints for through-hole components in KiCad, and I've got some issues determining the correct pad dimensions from manufacturer's technical drawings.
As an example, here's the drawing for a Fairchild BC547 - TO-92 package (line spacing lead form - dimensions in millimetres):
First of all, having two values for the same dimension should in my understanding indicate min/max values.
I don't want the drills to be too large, as I like when the component somehow stick to the board when soldering from the bottom side.
So in such a case, what would the ideal drill size and pad size for 0.56/0.36 and spacing for 2.80/2.40?
You may want to have a look at the IPC through hole standards or have a look at this page, where it is a little easier to understand.
In your example:
Minimum Hole Size
Pad is 0.56mm x 0.52mm => sqrt(0.56^2 + 0.52^2) = 0.76mm Minimum Hole Size = Maximum Lead Diameter + 0.25mm = 0.76mm + 0.25mm
If you like your components to "stick" you may want to choose Level C (+ 0.15mm)
Pad Diameter
Pad Diameter = Minimum Hole Size + 0.1mm + 0.60mm = 1.01mm+0.1mm+0.6mm = 1.71mm
  • \$\begingroup\$ Thanks a lot for the answer and the awesome references. This solves the drill and pad size issues, but then what to do about spacing between the leads, with min/max values? \$\endgroup\$
    – Macmade
    Commented Oct 28, 2015 at 21:04
    \$\begingroup\$ Since the nominal is not in the drawing, use either (min+max)/2 = 2.6mm or you could use 2.54mm which is stated as nominal on the NXP datasheet. \$\endgroup\$ Commented Oct 29, 2015 at 3:10
  • \$\begingroup\$ Can you please clarify what your "Minimum Hole Size" is the size of? EDA software typically wants the DRILL size, not the post plating residual hole size. Are you saying that your 0.25mm example allowance includes for the subsequent plating? Seems tight... \$\endgroup\$
    – Paul Uszak
    Commented Aug 13, 2019 at 1:30
