I am getting full scale ADC value from 4000 to 20000. I am trying to convert o 0-400 mbar pressure, as I am ultimately measuring height of a tank.
I have a equation to measure the Height of Liquid.
Pressure Eq.
\$ L = \dfrac{P}{ \rho \cdot g} \$
\$ \rho = \rho_{0} \cdot SG \$
\$ SG = 1.033 \text{ (Specific Gravity of Milk)} \$
\$ \rho_{0} = 1 \text{ (Density of fresh water)} \$
\$ \rho = 1.033 \$
\$ P = \text{ADC Coutn To MiliBar Or Bar Value} \$
But how can I convert the ADC value to Milibar or Bar value?
  • \$\begingroup\$ Where is the equation for pressure? \$\endgroup\$ – Ignacio Vazquez-Abrams Oct 29 '15 at 9:33
    \$\begingroup\$ Well in the ideal case you have a linear relationship between ADC value and pressure, so just draw a diagram, put the ADC values on the X-axis, the pressure values on the Y-axis. Put the points in there, connect them, think about how you get a formula out of it to describe what you just drawn. \$\endgroup\$ – Arsenal Oct 29 '15 at 9:45
    \$\begingroup\$ If it is a linear relationship, google y=mx+c. \$\endgroup\$ – Tom Carpenter Oct 29 '15 at 13:28
  • \$\begingroup\$ I thought linear equations was mandatory prerequisite knowledge before studying programming... \$\endgroup\$ – Lundin Oct 29 '15 at 15:00
If your ADC goes from 4000 to 20000 it means you have 16000 point to mesure 400mbar.
Then the resolution of your mesure is:
resolution= 400/16000 = 0.025mbar.
And you have an offset of 4000 point.
Then your value in mbar is : P = (ADCvalue - offset) * resolution.
