I came across this circuit diagram above and I want to implement it but I really need an explanation on the function of the components used in the circuit diagram especially RFC and the diodes (D1 and D2).
Your inputs will be greatly appreciated.
  • \$\begingroup\$ Try looking at this question: electronics.stackexchange.com/questions/198204/… - it has a more regular version of the ZVS driver circuit and an instructable link - it's going to give you a better source of knowledge and a term to search for "ZVS Driver". \$\endgroup\$
    Commented Oct 31, 2015 at 9:59
  • \$\begingroup\$ What I actually want to understand, Andy is the function of the diodes and the RFCs \$\endgroup\$ Commented Oct 31, 2015 at 11:17
Here's a very similar circuit: -
Stolen from here and this is the explanation (which I agree with): -
The circuit works by one mosfet turning on due to differences in the gate resistors or internal structure of the mosfet. Once on, the opposite mosfet will be held off by the fast diodes. The voltage across one primary half will rise up an fall again in a half-sine wave. Once at zero the mosfet that was on will be forced off, and the mosfet which was held off will be allowed on. The cycle repeats in opposite this time, before returning to where it started. The large inductor serves as a "current capacitor", providing constant current to the driver. Thanks to the resonant action of the circuit, it benefits from ZVS, or Zero Voltage Switching. This means that the mosfets switch on with no voltage across them, so while they transistion from off to on they won't dissiapte power. (P = I * V)
The above uses one RFC at the centre tap of the transformer. The circuit in the question doesn't use a centre tapped transformer hence needs two RFCs. The RFCs are acting as current sources to develop the AC signal upon - they bias the transistors without acting as too much of a load for the switching AC waveforms on the actual transformer.
Here is a link to another stack exchange answer I gave on ZVS drivers that may be of interest.
  • \$\begingroup\$ Thanks Andy. Since you have such great insight on this tech. I will be bringing up issues about my progress in the work I am doing currently to you if that will be okay with you. \$\endgroup\$ Commented Nov 2, 2015 at 10:48
  • \$\begingroup\$ @UcheOhajuru yeah keep informing if you hit problems and, if you consider this question answered you might consider "marking" it as "accepted". No hurry, and you can ask newer questions as this evolves. \$\endgroup\$
    Commented Nov 2, 2015 at 11:14
  • \$\begingroup\$ But Andy, what are the functions of the diodes in the circuit theoretically speaking? \$\endgroup\$ Commented Nov 2, 2015 at 11:39
  • \$\begingroup\$ "Once on, the opposite mosfet will be held off by the fast diodes" - the diodes prevent both mosfets being on. \$\endgroup\$
    Commented Nov 2, 2015 at 11:41
  • \$\begingroup\$ I mean the the diodes in the circuit that I posted. \$\endgroup\$ Commented Nov 2, 2015 at 13:17
It appears that these components are being used to bias the transistors and provide timing so that you get an AC signal to the transformer. You could make a similar circuit using a joule thief instead, although you might not get as much efficiency or power handling.
  • \$\begingroup\$ Thanks Daniel. But, why are they using an RF choke? \$\endgroup\$ Commented Oct 31, 2015 at 9:57
  • \$\begingroup\$ Probably to prevent the RF from coupling into the bias circuit \$\endgroup\$
    – Daniel
    Commented Oct 31, 2015 at 19:11
