In a logic circuit, I have an 8-bit data vector that is fed into an ECC IC which I am supposed to develop the logic for and that contains a vector of 5 Parity Bits. My first step to develop the logic (with logic gates, XOR), is to figure out which parity bit is going to check for which Data bits (since they are interlaced). I am using even parity, and following general hamming code rules (a parity bit in every 2^n ), I get the following sequence of output:
P1 P2 D1 P3 D2 D3 D4 P4 D5 D6 D7 D8 P5
Following the General Hamming Algorithm:
For each parity bit, Position 1,2,4,8,16 and so on... (Powers of 2), we skip for the first position n (n-1) and we check 1 bit, then we skip another one, the check another one, etc... we repeat the same process for the other bits, but this time checking/skipping every 2^n, where n is the position they occupy in the output array (P1 P2 D1 P3 D2 D3 D4 P4 D5 D6 D7 D8 P5)
Following that convention, I get:
P1 Checks data bits -> XOR(3 5 7 9 10 12) P2 Checks data bits -> XOR(3 6 7 10 11) P3 Checks data bits -> XOR(5 6 10 11 12) P4 Checks data bits -> XOR(9 10 11)
Am I right? The thing that confuses me is that if I should start checking counting the parity bit as one of the 2^n bits that are supposed to be checked, or 1 bit after that specific parity bit. Pretty much sums up to if it is inclusive or not.
Thank you for your help in advance!
Cheers!
It is done inclusively ie by undertaking the parity bit under consideration, they are designed in such a way that along with the parity bit itself the data word or message bit generates the desired parity type in your case even parity.
Look at the image from wikipedia Parity table
Only parity 1 is included while calculating at position one and so on.
Position 1 Checks data bits -> XOR(1 3 5 7 9 10 12)
Position 2 Checks data bits -> XOR(2 3 6 7 10 11)
Position 4 Checks data bits -> XOR(4 5 6 7 12..)
Position 8 Checks data bits -> XOR(8 9 10 11...)
Remember don't confuse between position and parity number, the bit-stream are numbered (1-n), where n is the size of codeword.
Hence your P1 is position 1,your P2 is position 2, P3 is position 4, and P4 is position 8.
  • \$\begingroup\$ I kinda get it. We don't say that P1 covers itself, or can we say that? I need to implement this logic with logic gates, XORs to be specific, so I don't see how P1 would implement itself. \$\endgroup\$
    – Cesar A
    Oct 31, 2015 at 22:23
  • \$\begingroup\$ Do you happen to know how to implement that logic with XOR gates? Or at least could you give me a hint? The logic I am referring to is P1 = XOR(3, 5, 7 ,9, 11) \$\endgroup\$
    – Cesar A
    Oct 31, 2015 at 22:31
  • \$\begingroup\$ As I said it in the answer itself the parity bit along with other position gives you the even parity, as it is at position P1 so position 1 has P1 in it(P1 cover itself and so does P2 ...), also you try cascading multiple XOR gates to get the parity check. For more information XOR gate \$\endgroup\$
    – MaMba
    Nov 1, 2015 at 8:55
