-2
How can we accurately detect whether window/door is opened using different sensors?
Window Switches are most common and accurate way.
Questions: 1.Is it common to use air pressure detection to solve such problems? Can it be done accurately? This thread mentioned to use MS5611 sensor. Can it solve the issue? Volumetric air sensor for burglar alarm 2.Are there any other accurate way (other than air pressure detection and switches) that can be used to solve this problem?
  • \$\begingroup\$ Are you trying to find out the state of a door/window, or are you trying to detect intruders? \$\endgroup\$ – user1844 Oct 31 '15 at 17:00
  • \$\begingroup\$ @WillDean : To find state of door/window \$\endgroup\$ – rushi121 Oct 31 '15 at 18:00
    \$\begingroup\$ Stop posting multiple questions on the same problem. \$\endgroup\$ – Chris Stratton Dec 12 '15 at 18:40
I don't think there could ever be a definitive list of ways you could detect the state of the door/window, but obvious ones are:
  • Proximity switch (like magnetic window switch used in alarms)
  • Mechanical switch (like in a refrigerator, or older car)
  • Some kind of optical detection: beam-break or retroflective
  • Image analysis using a camera
Air pressure is used to detect doors/windows opening/closing suddenly, not to detect the static state of doors/window.
I would suggest that 99.9999% of all doors/windows in the world which have switches on them use one of the first two techniques.
  • \$\begingroup\$ Can we use passive infrared proximity sensor ( adafruit.com/products/466 ) that is used in mobile phones as a way to detect whether window is opened or closed? The device (that has sensor) is placed on window glass and when that device detects a window frame it will trigger alarm. Will it work even if bright sunlight is on the window? I don't want to use window sensors with magnetic switch. \$\endgroup\$ – rushi121 Dec 12 '15 at 18:23
