38
When driving an LED with PWM, the brightness (as I perceive it) does not scale linearly with duty cycle. The brightness is slow to ramp up, then increases exponentially with duty cycle.
Can anyone suggest a rule of thumb to use as a correction factor, or other workaround?
    \$\begingroup\$ When I made a pair of Knight Rider cuff links, I had to use x^10 to make the fade off look nice! \$\endgroup\$ Sep 9, 2013 at 20:05
  • 4
    \$\begingroup\$ Are you sure it's not "the brightness initially increases exponentially, and then is slow to ramp up"? \$\endgroup\$ Dec 22, 2015 at 8:17
    \$\begingroup\$ I believe our eyes respond logarithmically to brightness. \$\endgroup\$
    – DKNguyen
    Jun 14, 2019 at 22:24
12 Answers 12
15
For 16 levels it's easy to do a simple look-up table "by hand" and convert the 4 bit value in an 8 bit value to pass to PWM controller: this is the component i've used in my FPGA led array driver. For an 8 bit level controller, you'll need at least 11-12 bit output from the look-up table.
library IEEE;
use IEEE.Std_logic_1164.all;
entity Linearize is
port ( reqlev : in std_logic_vector (3 downto 0) ;
    pwmdrive : out std_logic_vector (7 downto 0) );
    end Linearize;
architecture LUT of Linearize is
    begin
    with reqlev select
        pwmdrive <= "00000000" when "0000",
                    "00000010" when "0001",
                    "00000100" when "0010",
                    "00000111" when "0011",
                    "00001011" when "0100",
                    "00010010" when "0101",
                    "00011110" when "0110",
                    "00101000" when "0111",
                    "00110010" when "1000",
                    "01000001" when "1001",
                    "01010000" when "1010",
                    "01100100" when "1011",
                    "01111101" when "1100",
                    "10100000" when "1101",
                    "11001000" when "1110",
                    "11111111" when "1111",
                    "00000000" when others;
    end LUT;
    \$\begingroup\$ I'm trying to figure out exactly what your formula is. It's remarkably close to f(x)=x^2, but the curve isn't quite deep enough. f(x)=x^3/13 gets me a lot closer. \$\endgroup\$
    – ajs410
    Sep 27, 2010 at 19:30
    \$\begingroup\$ It's no formula (not intentionally)... I've trown in the linearizer initial values just guessing:-). I've then powered the array, driving led columns in brightness order, and tweaked the values to get an even ramp. It's really easy with only 16 levels. \$\endgroup\$
    – Axeman
    Oct 2, 2010 at 10:58
    \$\begingroup\$ @ajs410 - looks more like \$2^n\$ to me: the first 1 bit more or less shifts left 1 position to the left with each step. \$\endgroup\$
    – stevenvh
    Jul 16, 2011 at 6:16
19
In theory it should be exponential, but I've got best results for fading by using a quadratic function.
I also think you got it backwards. At low duty cycle the perceived increase in brightness is much bigger than at almost full duty cycle, where the increase in brightness is almost imperceivable.
I've been looking in to this subject over the last few days as I have the same problem... trying to dim LEDs using PWM in a visibly linear way, but I want full 256 step resolution. Trying to guess 256 numbers to manually create a curve is not an easy task!
I'm not an expert mathematician, but I know enough to generate some basic curves by combining a few functions and formulas without really knowing how they work. I find that using a spreadsheet (I used Excel) you can play around with a set of numbers from 0 to 255, put a few formulas in the next cell, and graph them.
I'm using pic assembler to do the fading, and so you can even get the spreadsheet to generate the assembler code with a formula (="retlw 0x" & DEC2HEX(A2)). This makes it very quick and easy to try out a new curve.
After a bit of playing around with LOG and SIN functions, the average of the two, and a few other things, I couldn't really get the right curve. What is happening is that the middle part of the fade was happening slower than the lower and higher levels. Also, if a fade-up is immediately followed by a fade-down there was a sharp noticeable spike in the intensity. What is needed (in my opinion) is an S curve.
A quick search on Wikipedia came up with the formula needed for an S curve. I plugged this into my spreadsheet, and made a few adjustments to make it multiply across my range of values, and came up with this:
S curve
I tested it on my rig, and it worked beautifully.
The Excel formula I used was this:
=1/(1+EXP(((A2/21)-6)*-1))*255
where A2 is the first value in column A, which increases A3, A4, ..., A256 for each value.
I have no idea if this is mathematically correct or not, but it produces the desired results.
Here are the full set of 256 levels that I used:
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01,
0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x01, 0x02, 0x02, 0x02, 0x02, 0x02, 0x02, 0x02,
0x02, 0x02, 0x03, 0x03, 0x03, 0x03, 0x03, 0x03, 0x04, 0x04, 0x04, 0x04, 0x04, 0x05, 0x05, 0x05,
0x05, 0x06, 0x06, 0x06, 0x07, 0x07, 0x07, 0x08, 0x08, 0x08, 0x09, 0x09, 0x0A, 0x0A, 0x0B, 0x0B,
0x0C, 0x0C, 0x0D, 0x0D, 0x0E, 0x0F, 0x0F, 0x10, 0x11, 0x11, 0x12, 0x13, 0x14, 0x15, 0x16, 0x17,
0x18, 0x19, 0x1A, 0x1B, 0x1C, 0x1D, 0x1F, 0x20, 0x21, 0x23, 0x24, 0x26, 0x27, 0x29, 0x2B, 0x2C,
0x2E, 0x30, 0x32, 0x34, 0x36, 0x38, 0x3A, 0x3C, 0x3E, 0x40, 0x43, 0x45, 0x47, 0x4A, 0x4C, 0x4F,
0x51, 0x54, 0x57, 0x59, 0x5C, 0x5F, 0x62, 0x64, 0x67, 0x6A, 0x6D, 0x70, 0x73, 0x76, 0x79, 0x7C,
0x7F, 0x82, 0x85, 0x88, 0x8B, 0x8E, 0x91, 0x94, 0x97, 0x9A, 0x9C, 0x9F, 0xA2, 0xA5, 0xA7, 0xAA,
0xAD, 0xAF, 0xB2, 0xB4, 0xB7, 0xB9, 0xBB, 0xBE, 0xC0, 0xC2, 0xC4, 0xC6, 0xC8, 0xCA, 0xCC, 0xCE,
0xD0, 0xD2, 0xD3, 0xD5, 0xD7, 0xD8, 0xDA, 0xDB, 0xDD, 0xDE, 0xDF, 0xE1, 0xE2, 0xE3, 0xE4, 0xE5,
0xE6, 0xE7, 0xE8, 0xE9, 0xEA, 0xEB, 0xEC, 0xED, 0xED, 0xEE, 0xEF, 0xEF, 0xF0, 0xF1, 0xF1, 0xF2,
0xF2, 0xF3, 0xF3, 0xF4, 0xF4, 0xF5, 0xF5, 0xF6, 0xF6, 0xF6, 0xF7, 0xF7, 0xF7, 0xF8, 0xF8, 0xF8,
0xF9, 0xF9, 0xF9, 0xF9, 0xFA, 0xFA, 0xFA, 0xFA, 0xFA, 0xFB, 0xFB, 0xFB, 0xFB, 0xFB, 0xFB, 0xFC,
0xFC, 0xFC, 0xFC, 0xFC, 0xFC, 0xFC, 0xFC, 0xFC, 0xFD, 0xFD, 0xFD, 0xFD, 0xFD, 0xFD, 0xFD, 0xFD,
0xFD, 0xFD, 0xFD, 0xFD, 0xFD, 0xFD, 0xFD, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFF, 0xFF
  • \$\begingroup\$ This equation worked perfectly for me. \$\endgroup\$ Sep 19, 2013 at 20:57
7
I was using an ATtiny for lighting my deck. Brightness is controlled using a pot connected to ADC pin.
Tried exponential function and the PWM output based on that seems to be giving linear increase in perceived brightness.
I was using this formulae:
out = pow(out_max, in/in_max)
Attiny85 @8MHz was taking about 210us to perform the above calculation. To improve the performance, made a lookup table. Since input was from 10-bit ADC and ATtiny memory is limited, I wanted to create a shorter table as well.
Instead of making lookup table with 1024 entries, made a reverse lookup table with 256 entries (512 bytes) in program memory (PGMEM). A function was written to perform binary search on that table. This method takes only 28uS for each lookup. If I use a direct lookup table, it would require 2kb memory, but lookup would take only 4uS or so.
Calculated values in lookup table uses input range 32-991 only, discarding lower/upper range of ADC, in case there is problem with circuit.
Below is what I have now.
// anti_log test program
/*LED connected to PIN6(PB1)*/
#define LED 1
// Anti-Log (reverse) lookup table
// y = 0-255 (pwm output), y_range=256
// x = 0-1023 (10-bit ADC input);
// assuming lower/higher end of ADC out values cannot be used
// discarding first 32 and last 32 values.
// min_x = 32, max_x = 1023-min_x, x_range=1024-2*min_x
// ANTI_LOG[y] = round( x_range*log(y, base=y_range) + min_x )
// given a value of x, perform a binary lookup on below table
// takes about 28uS for Attiny85 @8MHz clock
PROGMEM prog_uint16_t ANTI_LOG[] = {
  0x0000, 0x0020, 0x0098, 0x00de, 0x0110, 0x0137, 0x0156, 0x0171, 0x0188, 0x019c, 0x01af, 0x01bf, 0x01ce, 0x01dc, 0x01e9, 0x01f5,
  0x0200, 0x020a, 0x0214, 0x021e, 0x0227, 0x022f, 0x0237, 0x023f, 0x0246, 0x024d, 0x0254, 0x025b, 0x0261, 0x0267, 0x026d, 0x0273,
  0x0278, 0x027d, 0x0282, 0x0288, 0x028c, 0x0291, 0x0296, 0x029a, 0x029f, 0x02a3, 0x02a7, 0x02ab, 0x02af, 0x02b3, 0x02b7, 0x02bb,
  0x02be, 0x02c2, 0x02c5, 0x02c9, 0x02cc, 0x02cf, 0x02d3, 0x02d6, 0x02d9, 0x02dc, 0x02df, 0x02e2, 0x02e5, 0x02e8, 0x02eb, 0x02ed,
  0x02f0, 0x02f3, 0x02f5, 0x02f8, 0x02fa, 0x02fd, 0x0300, 0x0302, 0x0304, 0x0307, 0x0309, 0x030b, 0x030e, 0x0310, 0x0312, 0x0314,
  0x0317, 0x0319, 0x031b, 0x031d, 0x031f, 0x0321, 0x0323, 0x0325, 0x0327, 0x0329, 0x032b, 0x032d, 0x032f, 0x0331, 0x0333, 0x0334,
  0x0336, 0x0338, 0x033a, 0x033c, 0x033d, 0x033f, 0x0341, 0x0342, 0x0344, 0x0346, 0x0347, 0x0349, 0x034b, 0x034c, 0x034e, 0x034f,
  0x0351, 0x0352, 0x0354, 0x0355, 0x0357, 0x0358, 0x035a, 0x035b, 0x035d, 0x035e, 0x0360, 0x0361, 0x0363, 0x0364, 0x0365, 0x0367,
  0x0368, 0x0369, 0x036b, 0x036c, 0x036d, 0x036f, 0x0370, 0x0371, 0x0372, 0x0374, 0x0375, 0x0376, 0x0378, 0x0379, 0x037a, 0x037b,
  0x037c, 0x037e, 0x037f, 0x0380, 0x0381, 0x0382, 0x0383, 0x0385, 0x0386, 0x0387, 0x0388, 0x0389, 0x038a, 0x038b, 0x038c, 0x038e,
  0x038f, 0x0390, 0x0391, 0x0392, 0x0393, 0x0394, 0x0395, 0x0396, 0x0397, 0x0398, 0x0399, 0x039a, 0x039b, 0x039c, 0x039d, 0x039e,
  0x039f, 0x03a0, 0x03a1, 0x03a2, 0x03a3, 0x03a4, 0x03a5, 0x03a6, 0x03a7, 0x03a8, 0x03a9, 0x03aa, 0x03ab, 0x03ab, 0x03ac, 0x03ad,
  0x03ae, 0x03af, 0x03b0, 0x03b1, 0x03b2, 0x03b3, 0x03b4, 0x03b4, 0x03b5, 0x03b6, 0x03b7, 0x03b8, 0x03b9, 0x03ba, 0x03ba, 0x03bb,
  0x03bc, 0x03bd, 0x03be, 0x03bf, 0x03bf, 0x03c0, 0x03c1, 0x03c2, 0x03c3, 0x03c3, 0x03c4, 0x03c5, 0x03c6, 0x03c7, 0x03c7, 0x03c8,
  0x03c9, 0x03ca, 0x03ca, 0x03cb, 0x03cc, 0x03cd, 0x03cd, 0x03ce, 0x03cf, 0x03d0, 0x03d0, 0x03d1, 0x03d2, 0x03d3, 0x03d3, 0x03d4,
  0x03d5, 0x03d6, 0x03d6, 0x03d7, 0x03d8, 0x03d8, 0x03d9, 0x03da, 0x03db, 0x03db, 0x03dc, 0x03dd, 0x03dd, 0x03de, 0x03df, 0x03df
// Binary lookup using above table.
byte antilog( int x )
  byte y = 0x80;
  int av;
  for( int i=0x40; i>0; i>>=1 )
    av = pgm_read_word_near( ANTI_LOG+y );
    if ( av > x )
      y -= i;
    else if ( av < x )
      y |= i;
    else
      return y;
  if ( pgm_read_word_near( ANTI_LOG+y ) > x )
    y -= 1;
  return y;
void setup()
  pinMode( LED, OUTPUT );
  digitalWrite( LED, LOW );
#define MIN_X 0
#define MAX_X 1024
void loop()
  int i;
  // antilog_drive
  for( i=MIN_X; i<MAX_X; i++ )
    analogWrite( LED, antilog( i ) );
    delay( 2 );
  for( --i; i>=MIN_X; i-- )
    delay( 2 );
  delay( 1000 );
  // Linear drive
    analogWrite( LED, i>>2 );
    delay( 2 );
    delay( 2 );
  delay( 2000 );
I found this guy who uses a method he calls "Anti-Log Drive". Here is the direct download link for his info.
This PDF explains the curve needed, apparently a logarithmic one. If you have a linear dimmer (your PWM value) then the function should be logarithmic.
Here you can find a lookup table for 32 steps of brightness for 8 bit PWM.
Here for 16 steps.
Here is what I have done based on that arduino forum response. I have computed the values from 0 to 255 so it's easy to use with pwm on arduino
byte ledLookupTable[] = {0,0,0,0,0,0,0,0,0,0,0,0,1,1,1,1,1,1,1,1,2,2,2,2,2,2,3,3,3,3,4,4,4,4,5,5,5,5,6,6,6,7,7,7,8,8,8,9,9,9,10,10,11,11,11,12,12,13,13,14,14,15,15,16,16,17,17,18,18,19,19,20,20,21,21,22,23,23,24,24,25,26,26,27,28,28,29,30,30,31,32,32,33,34,35,35,36,37,38,38,39,40,41,42,42,43,44,45,46,47,47,48,49,50,51,52,53,54,55,56,56,57,58,59,60,61,62,63,64,65,66,67,68,69,70,71,73,74,75,76,77,78,79,80,81,82,84,85,86,87,88,89,91,92,93,94,95,97,98,99,100,102,103,104,105,107,108,109,111,112,113,115,116,117,119,120,121,123,124,126,127,128,130,131,133,134,136,137,139,140,142,143,145,146,148,149,151,152,154,155,157,158,160,162,163,165,166,168,170,171,173,175,176,178,180,181,183,185,186,188,190,192,193,195,197,199,200,202,204,206,207,209,211,213,215,217,218,220,222,224,226,228,230,232,233,235,237,239,241,243,245,247,249,251,253,255};
Then to use on Arduino just do like that :
analogWrite(ledPin, ledLookupTable[brightness]); //with brighness between 0 and 255
Hope it is helpfull for some people ;)
I'm dealing with this now, and I'm taking a slightly different approach. I want 256 levels of brightness, but mapping a linear 0-255 range to a non-linear 0-255 range winds up, as you can see in some of the other answers, with a lot of duplicate entries. (I.e., several of your input values result in the same brightness level.)
I tried modifying the algorithm to map a 0-256 input range to a 0-1023 output range, but even that had several values mapping to 0. So I'm trying something a bit different - I'm using the 0-255 level to generate non-linear values in the range 0-769 (that's 1023 minus 255) using sin(), then add that to the input level to get an output in the range 0-1023 with no duplicates. I'll configure a timer to use a counter of 1023, and set the comparator for the PWM output to values from the lookup table based on what lighting level I want (0-255).
Here's the C program I used to generate my lookup table:
#include <stdio.h>
#include <math.h>
int main() {
    int i;
    double j;
    int k;
    printf( "int brightness[] = {\n" );
    for( i=0; i<256; i++ ) {
        // 0 - 255 => 1.0 - 0.0, multiply by 90 degrees (in radians)
        j = (1 - (i / 255.0)) * M_PI / 2;
        j = sin( j );
        k = (1023-255) - j * (1023-255);
        printf( "%s%d%s%s",
                (((i % 8) == 0) ? "    " : " "), // leading space at start of line
                k+i,
                ((i < 255) ? "," : ""),          // comma after all but last value
                (((i % 8) == 7) ? "\n" : "")     // line break every 8 items
    printf( "  };\n" );
And here's the table:
    0, 1, 2, 3, 4, 5, 6, 7,
    8, 10, 11, 12, 14, 15, 16, 18,
    19, 21, 22, 24, 25, 27, 29, 30,
    32, 34, 35, 37, 39, 41, 43, 44,
    46, 48, 50, 52, 54, 56, 58, 61,
    63, 65, 67, 69, 72, 74, 76, 78,
    81, 83, 86, 88, 91, 93, 96, 98,
    101, 103, 106, 109, 111, 114, 117, 120,
    122, 125, 128, 131, 134, 137, 140, 143,
    146, 149, 152, 155, 158, 161, 164, 168,
    171, 174, 177, 181, 184, 187, 191, 194,
    198, 201, 205, 208, 212, 215, 219, 222,
    226, 230, 233, 237, 241, 244, 248, 252,
    256, 260, 263, 267, 271, 275, 279, 283,
    287, 291, 295, 299, 303, 307, 312, 316,
    320, 324, 328, 333, 337, 341, 345, 350,
    354, 358, 363, 367, 372, 376, 381, 385,
    390, 394, 399, 403, 408, 412, 417, 422,
    426, 431, 436, 440, 445, 450, 455, 459,
    464, 469, 474, 479, 484, 489, 493, 498,
    503, 508, 513, 518, 523, 528, 533, 538,
    543, 548, 554, 559, 564, 569, 574, 579,
    584, 590, 595, 600, 605, 610, 616, 621,
    626, 632, 637, 642, 647, 653, 658, 664,
    669, 674, 680, 685, 690, 696, 701, 707,
    712, 718, 723, 729, 734, 740, 745, 751,
    756, 762, 767, 773, 778, 784, 790, 795,
    801, 806, 812, 818, 823, 829, 834, 840,
    846, 851, 857, 863, 868, 874, 880, 885,
    891, 897, 902, 908, 914, 920, 925, 931,
    937, 942, 948, 954, 960, 965, 971, 977,
    982, 988, 994, 1000, 1005, 1011, 1017, 1023
I'll probably investigate other functions (like log()) once I've got this up and running.
For me this law seem to work pretty good: http://www.pyroelectro.com/tutorials/fading_led_pwm/theory2.html
Ok so I just had to deal with this. According to this link, while the emitted light is linear with the increase in PWM duty cycle, our perception of it is not linear, but logarithmic.
We can transform it to be perceived as linear by applying an exponential function to it. With a python example:
exp_scaler = 100/(math.exp(1)-1)
def change(v):
    pwm.ChangeDutyCycle(int((math.exp(v)-1)*exp_scaler))
where v ranges between 0-1.
This should be easy to translate to any other language (ChangeDutyCycle expects values between 0-100, so scale accordingly).
Some times ago, I designed a PWM controller for a LED strip. In first tests, I verified that perceived brightness was not linear with the PWM duty cycle. For example, with 50% d.c. PWM, the perceived brightness was much more than the 50% of its maximum value with 100% d.c. PWM. In fact, human eye perceives light intensity in a logarithmic way, because only in this way it can adapt to strong variations like sun-light and shadow.
You can assume the following relation:
$$ L_{perceived} \propto log(d.c.) $$
To solve that problem, you can build up a LUT to convert desired brightness into PWM values. With the desired perceived brightness L in the range 0-1, you should get good results with this empirical formula:
$$ d.c._{\%} = \frac{10^{L} - 1}{9} \cdot 100\% $$
If the goal is only a smooth brightness level ramp-up through the full-range of possible brightness levels:
The time step linearly decreasing as the brightness increases with a constant step, results in the brightness level exponentially increasing in time.
Example:
#define MAX_DUTY 255
#define MIN_DUTY 0
#define RAMP_DOWN 0
#define RAMP_UP 1
#define MIN_DELAY 100UL
#define MAX_DELAY 1000UL
void loop(void)
    uint32_t delay;
    uint8_t duty;
    int8_t ramp_dir;
    duty = MIN_DUTY;
    ramp_dir = RAMP_UP;
    for (;;) {
            // Offset by +1 to avoid division by zero
        for (delay = MIN_DELAY + ((MAX_DELAY - MIN_DELAY) * (MAX_DUTY + 1)) / (duty + 1); delay > 0; delay--) {
            ; // Wait
        if (ramp_dir) {
            if (duty < MAX_DUTY) {
                duty++;
            } else {
                duty--;
                ramp_dir = RAMP_DOWN;
        } else {
            if (duty > MIN_DUTY) {
                duty--;
            } else {
                duty++;
                ramp_dir = RAMP_UP;
        set_led_duty(duty);
