First, I set the output terminal of function generator to 50ohm and output voltage amplitude to 8Vp-p. Then I change the terminal to Hi Z and removed the 50ohm load. Why does the displayed voltage of the function generator became 16Vp-p while the voltage displayed on oscilloscope remain 8Vp-p?
It is a Agilent 33220A function generator and DSO-X 2002A oscilloscope.
  • \$\begingroup\$ Can you provide screenshots of the scope? \$\endgroup\$
    – Curd
    Nov 2, 2015 at 1:58
We had these in collage years ago, the High Z and 50 Ohm is just software. I can't remember what direction is right but one setting just multiplied or divided the real voltage by a factor of 2.
Trust the scope.
