I have a wireless keyboard that uses rechargeable Lithium-ion battery, the battery is flat and it won't recharge, instead the circuit becomes very hot. I checked the coponents on the circuit for any sign of burns or faults but every thing seems to be fine, the only peice that's heating up is a 6 pins IC labelled 017tL, i think that it is the battery charge IC, However i couldn't find it on the interent.
This is the circuit and the red line points to the 017tL IC:
I couldn't find any schematics for this device and the 017tL component is not available on Amazon or Ebay, Is there an equivalent replacement part that i can buy?
  • \$\begingroup\$ It could also be the battery that is bad. Do you have the ability to test the battery by charging/discharging it using a different charger or some kind of test equipment? \$\endgroup\$
    – mkeith
    Nov 2 '15 at 16:46
  • \$\begingroup\$ no i havn't tested the battery but i don't think it's dead because the device is only 5 months old and i charged it only twice using the USB cable from my laptop. \$\endgroup\$
    – razzak
    Nov 2 '15 at 16:51
  • \$\begingroup\$ Something is defective. It could be the battery. I see your point, that it shouldn't yet be worn out because it is relatively new. But the IC also should not be bad. Anyway, testing the battery would be a good idea only if you can do it easily. If not, then you can try replacing the IC and see what happens. \$\endgroup\$
    – mkeith
    Nov 2 '15 at 16:55
That chip looks to be a Seaward Electronics SE9017-LF. "Standalone Linear Lithium Battery Charger". You can download the datasheet from this page.
I found this by googling "017tl ic". Somehow Google made the link between that part marking and the actual IC part number; I didn't see the "017tl" marking anywhere on the datasheet.
I cannot find this IC from any of my standard distributors in the USA. It looks like Alibaba has it in high quantity :) Hopefully you can find someone that will sell in smaller batches.
  • \$\begingroup\$ Thanks i found another link that says it's 017tL, this should do the job \$\endgroup\$
    – razzak
    Nov 2 '15 at 16:56
