Following a previous suggestion in this post i tried to write by my self an example, but it doesn't work.
Top entity
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_misc.all;
use ieee.numeric_std.all;
entity topEntity is
generic(m : natural);
port(x : in std_logic_vector(m - 1 downto 0));
end topEntity;
architecture rtl of topEntity is
component componentEntity is
generic(n : natural);
port(x : in std_logic_vector(n - 1 downto 0));
end component;
begin
INSTANCE : componentEntity
generic map(n => m)
port map(x(n - 1) => '0', x(n - 2 downto 0) => x(m - 2 downto 0));
end architecture rtl;
Component entity
library ieee;
entity componentEntity is
end entity;
architecture foo of componentEntity is
begin
end architecture foo;
when i run ncvhdl -v93 it says:
ncvhdl: 15.10-s008: (c) Copyright 1995-2015 Cadence Design Systems, Inc.
ncvhdl_p: *E,IDENTU (topEntity.vhd,19|13): identifier (N) is not declared [10.3].
why it's not declared? it's a generic parameter properly initialized.
Update:
I putted:
port map(x(m - 1) => '0', x(m - 2 downto 0) => x(m - 2 downto 0));
The result is
ncvhdl_p: *E,FMLNLS (topEntity.vhd,19|12): formal must be identified a locally static name 87[4.3.3.2] 93[4.3.2.2].
ncvhdl_p: *E,FMLNLS (topEntity.vhd,19|29): formal must be identified a locally static name 87[4.3.3.2] 93[4.3.2.2].
ncvhdl_p: *E,UFPTID (topEntity.vhd,19|29): port (X) must be associated [1.1.1.2].
Updated 2...
Still trying to figure out what it is the problem with all these kind of declaration/mapping in vhdl... my new attempt is:
The error report that formal must be identified a locally static name
I found a glossary where each term of interest for this error is explained it also refers to the language standard:
locally static name: A name in which every expression is locally static (if every discrete range that appears as part of the name denotes a locally static range or subtype and if no prefix within the name is either an object or value of an access type or a function call). (§6.1)
locally static expression: An expression that can be evaluated during the analysis of the design unit in which it appears. (§7.4, §7.4.1)
analysis: The syntactic and semantic analysis of source code in a VHDL design file and the insertion of intermediate form representations of design units into a design library. (§1 1.1, §11.2, §11.4)
There's also the error with the port (X) must be associated
So i guess the problem could be that the name of the top entity input is x
which is the same name as the component input. However i'm not sure about this because in general with port mapping like x => x
don't cause any trouble to me...
Looking at the standard as static name it spits out that:
A name is said to be a static name if and only if one of the following conditions holds: — The name is a simple name or selected name (including those that are expanded names) that does not denote a function call, an object or value of an access type, or an object of a protected type and (in the case of a selected name) whose prefix is a static name. — The name is an indexed name whose prefix is a static name, and every expression that appears as part of the name is a static expression. — The name is a slice name whose prefix is a static name and whose discrete range is a static discrete range.
Futhermore a specification is given for locally static name, which should help me to figure out the problem with the name:
a name is said to be a locally static name if and only if one of the following conditions hold: — The name is a simple name or selected name (including those that are expanded names) that is not an alias and that does not denote a function call, an object or value of an access type, or an object of a protected type and (in the case of a selected name) whose prefix is a locally static name. — The name is a simple name or selected name (including those that are expanded names) that is an alias, and that the aliased name given in the corresponding alias declaration (see 4.3.3) is a locally static name, and (in the case of a selected name) whose prefix is a locally static name. — The name is an indexed name whose prefix is a locally static name, and every expression that appears as part of the name is a locally static expression. — The name is a slice name whose prefix is a locally static name and whose discrete range is a locally static discrete range
So the issue should be that the name x
doesn't fall in any of the categories listed, but why?
x(n - 2 downto 0)
. You are trying to use generic n which is not declared within topEntity, but is only known inside the entity componentEntity and its architecture foo. \$\endgroup\$
