I have around 60-70 inverters that I want to talk to using arduino over RS-485. The connection that I am making with arduino is according to the attached image.
Now I think that my connection part is okay! Where I am falling behind is the coding part I guess. As for every request I am not able to make even one successful request. enter image description here
The modbus library that I am using is SimpleModbus Library here's the link to it: https://drive.google.com/folderview?id=0B0B286tJkafVSENVcU1RQVBfSzg&usp=drive_web
The data format that the inverter manufacturer is using is as follows: start byte, slave address, function code, data, check, end byte.
Whereas the request I am sending through my master device looks something like this:
packet1->id = 25; packet1->function = READ_HOLDING_REGISTERS; packet1->address = 3000; packet1->no_of_registers = 3; packet1->register_array = regs;
I am not including any start byte or end byte. Is it the reason why I am not able to receive any response from the slave device? or is it because I have to program the response of the slave devices as well?
As of now I am only playing around with the master device code and have not figured out on how to receive the response of the slave and how to decode it. Every modubs library seems to have two kinds of program one for the master and other for the slave. Whereas I use only the master code for sending requests to the slaves.
Do I have to program for slaves as well? if yes then how to program for both the master and slaves together on my master device arduino which is talking to my inverters?
I am new to arduino but experienced in programming. Just lack some basics in electronics and modubs protorcol over RS-485. Kindly please help me
Thanks in advance.
P.S: I have wired all my inverters through RS_485 ports correctly, I am connecting the negative end to the pin 7 on RS-485 chip and the positive wire to the pin 6 on the chip
  • \$\begingroup\$ This question is rather too broad and vague to give a useful answer to. What exactly is the problem you're having? If you haven't tried decoding a response yet, how do you know it's not responding? \$\endgroup\$ Commented Nov 3, 2015 at 14:01
  • \$\begingroup\$ It would be better to use an isolated rs485 driver board. You can do a lot of damage using this setup.. \$\endgroup\$ Commented Nov 3, 2015 at 14:01
  • \$\begingroup\$ I think this previous answer might be the solution for your question. \$\endgroup\$
    – Kvegaoro
    Commented Nov 3, 2015 at 15:25
  • \$\begingroup\$ @nickjohnson : I have a code to check no of requests send, successful requests and error. regs[3] = packet1->requests; regs[4] = packet1->successful_requests; regs[5] = packet1->total_errors; for every request my master device make, I don't get any response. \$\endgroup\$ Commented Nov 3, 2015 at 16:20
  • \$\begingroup\$ Which version of Arduino are you using? I know some versions use Pin 0 & 1 to communicate to the host PC, making them unavailable for use for other serial communications. \$\endgroup\$ Commented Nov 3, 2015 at 18:27
I don't have great knowledge about the Arduino platform, but I have worked with Modbus over 485 lines. All processors I used, requires pull-up resistors on the Tx-Rx lines to the MAX485. Maybe Arduino board implements internal pull-up resistors, can you verify this?
I have much doubt about the manufacturer's specification on the "start byte" and "end byte", this does not appear in the specification of Modbus protocol.
And finally, 60-70 nodes is a large node number... maybe you must check the specification for Modbus over serial line.
You should also be careful about the way to end the transmission line and how to perform wiring. Check the specifications.
Here is an example of a circuit that I used for Modbus over 485.
In this case, is an isolated line, but is the same principle.
Skip the MAX485 chip and communicate directly between two arduinos - this proves you can communicate TX to RX and vice versa - you can still use the same code libraries and I would suggest that what you might find is that you need both libraries installed at both ends but, you can prove this later - just try sending data from one arduino to another and let the recipient flash an LED if it receives the correct pre-defined message. Tackle the problem in stages with the final stage being getting the 485 stuff to work.
  • \$\begingroup\$ aka: thanks for your suggestion, I shall do that and come back to this. \$\endgroup\$ Commented Nov 3, 2015 at 16:23
I'm gonna guess that you didn't set the device IDs on the inverters. You need to set the device ID to a different number on each . Your master arduino must query each device individually,. I'd suggest that you use a PC with a free mobbus master to test the connection to the inverters. I used the simply modbus website for info to write a modbus master program a few months ago, very helpful site.
