I have a circuit with a variable resistor R which I need to find the value of. I am told that the power dissipated in the resistor is 250W.
The circuit:
I used the mesh current method naming the loops from left to right as Ia, Ib, and Ic.
These are my equations thus far:
25Ia + 100(Ia - Ib) - 200V = 0
10Ib + 20(Ib - Ic) + 30ix + 100(Ib - Ia) = 0
RIc - 30ix + 20(Ic-Ib) = 0
At this point I realized I needed a restraint equation for both ix and R. My ix restraint equation is:
ix - Ib = 0
For R's restraint equation, I related it to the power dissipated by the resistor which is 250W. I know that p = i^2 * R, so I can say that
250W = Ic^2 * R
However, when setting up my matrix I run into the problem of what to do with Ic^2. How would I set up the matrix to solve the system of equations using these equations? Or are my equations incorrect?
P.S. I cannot use any Thevenin stuff.
EDIT: The answer key I am looking at states that the two values or R should be 2.5 Ohms and 22.5 Ohms. I am just confused at how to arrive at those values.
  • \$\begingroup\$ As a separate equation or rewrite the 250W = Ic^2 * R equation? \$\endgroup\$
    – Zearia
    Nov 4, 2015 at 9:00
Your textbook answer is correct, and so are your equations (@Arka Sadhu probably just typed them wrong in Matlab). Anyway, here's how to cheat-solve this (first):
The transfer function of your circuit with the output considered the voltage over \$R_o\$ is
$$ V_o = \frac{200 R_o}{2 R_o + 15}$$
Since power over this resistor is \$V_o^2/R_o = 250\$, solve this equation to get exactly what your textbook said we should.
Now if we solve your system of equations (which is correct), but with R as a parameter, we get
Again if we use the value of the last current to solve for R given the power, we again get the same result:
From what I can see, your equations are correct. So all you need to do is set up the matrix using the first four equations, and get a Ia, Ib, Ic as a function of R0.
Then simply substitute the value of Ic(R0) into the last equation to get the value of R0.
I tried it on Matlab, and got R0 = 40 or 40/49.
  • \$\begingroup\$ Hm, are you sure that works? I think the values should be 2.5 and 22.5 Ohms. \$\endgroup\$
    – Zearia
    Nov 4, 2015 at 9:22
  • \$\begingroup\$ Looks like you typed the equations in wrong or something like that. \$\endgroup\$ Nov 5, 2015 at 22:51
