I'm trying to connect clock divider generated by CORE Generator to I2S receiver and I2S transmitter on Spartan 6. The PLL_BASE is connected via ODDR2 module, as adviced. Both receiver and transmitter work when clocks are divided without block from CORE Generator.
Code
clk_wiz_v3_6.vhd
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
use ieee.numeric_std.all;
library unisim;
use unisim.vcomponents.all;
entity clk_wiz_v3_6 is
port
(-- Clock in ports
CLK_IN1 : in std_logic;
-- Clock out ports
mclk : out std_logic;
sclk : out std_logic;
-- Status and control signals
RESET : in std_logic
end clk_wiz_v3_6;
architecture xilinx of clk_wiz_v3_6 is
attribute CORE_GENERATION_INFO : string;
attribute CORE_GENERATION_INFO of xilinx : architecture is "clk_wiz_v3_6,clk_wiz_v3_6,{component_name=clk_wiz_v3_6,use_phase_alignment=false,use_min_o_jitter=false,use_max_i_jitter=false,use_dyn_phase_shift=false,use_inclk_switchover=false,use_dyn_reconfig=false,feedback_source=FDBK_AUTO,primtype_sel=PLL_BASE,num_out_clk=2,clkin1_period=10.000,clkin2_period=10.000,use_power_down=false,use_reset=true,use_locked=false,use_inclk_stopped=false,use_status=false,use_freeze=false,use_clk_valid=false,feedback_type=SINGLE,clock_mgr_type=MANUAL,manual_override=false}";
-- Input clock buffering / unused connectors
signal clkin1 : std_logic;
-- Output clock buffering / unused connectors
signal clkfbout : std_logic;
signal clkout0 : std_logic;
signal clkout1 : std_logic;
signal clkout2_unused : std_logic;
signal clkout3_unused : std_logic;
signal clkout4_unused : std_logic;
signal clkout5_unused : std_logic;
-- Unused status signals
signal locked_unused : std_logic;
signal clk0obuf : std_logic;
signal clk0bufg : std_logic;
signal notclk0bufg : std_logic;
signal clk1bufg : std_logic;
signal notclk1bufg : std_logic;
signal clk1obuf : std_logic;
begin
notclk0bufg <= clk0bufg;
notclk1bufg <= clk1bufg;
-- Input buffering
clkin1_buf : IBUFG
port map
(O => clkin1,
I => CLK_IN1);
-- Clocking primitive
-- Instantiation of the PLL primitive
-- * Unused inputs are tied off
-- * Unused outputs are labeled unused
pll_base_inst : PLL_BASE
generic map
(BANDWIDTH => "OPTIMIZED",
CLK_FEEDBACK => "CLKFBOUT",
COMPENSATION => "INTERNAL",
DIVCLK_DIVIDE => 4,
CLKFBOUT_MULT => 29,
CLKFBOUT_PHASE => 0.000,
CLKOUT0_DIVIDE => 59,
CLKOUT0_PHASE => 0.000,
CLKOUT0_DUTY_CYCLE => 0.500,
CLKOUT1_DIVIDE => 118,
CLKOUT1_PHASE => 0.000,
CLKOUT1_DUTY_CYCLE => 0.500,
CLKIN_PERIOD => 10.000,
REF_JITTER => 0.010)
port map
-- Output clocks
(CLKFBOUT => clkfbout,
CLKOUT0 => clkout0,
CLKOUT1 => clkout1,
CLKOUT2 => clkout2_unused,
CLKOUT3 => clkout3_unused,
CLKOUT4 => clkout4_unused,
CLKOUT5 => clkout5_unused,
LOCKED => locked_unused,
RST => RESET,
-- Input clock control
CLKFBIN => clkfbout,
CLKIN => clkin1);
ODDR2_inst : ODDR2
generic map(
DDR_ALIGNMENT => "NONE",
INIT => '0',
SRTYPE => "SYNC")
port map (
Q => clk0obuf, -- 1-bit output data
C0 => clk0bufg, -- 1-bit clock input
C1 => NOTclk0bufg, -- 1-bit clock input
CE => '1', -- 1-bit clock enable input
D0 => '1',
D1 => '0',
R => '0', -- 1-bit reset input
S => '0' -- 1-bit set input
ODDR2_inst2 : ODDR2
generic map(
INIT => '0',
SRTYPE => "SYNC")
port map (
Q => clk1obuf, -- 1-bit output data
C0 => clk1bufg, -- 1-bit clock input
C1 => NOTclk1bufg, -- 1-bit clock input
D0 => '1',
D1 => '0',
-- Output buffering
clkout1_buf : BUFG
port map
(O => clk0bufg, --mclk
I => clkout0);
clkout2_buf : BUFG
port map
(O => clk1bufg, --sclk
I => clkout1);
clkout3_buf : OBUF
port map
(O => mclk, --mclk
I => clk0obuf);
clkout4_buf : OBUF
port map
(O => sclk, --sclk
I => clk1obuf);
end xilinx;
i2sClocks.vhd
library IEEE;
use IEEE.STD_LOGIC_1164.all;
use IEEE.NUMERIC_STD.all;
entity i2sClocks is
port
clk : in std_logic;
lrclk : out std_logic
end i2sClocks;
architecture rtl of i2sClocks is
signal i2sClocksDivider_i :std_logic_vector(6 downto 0) := (others => '0');
begin
lrclk <= i2sClocksDivider_i(6);
process(clk)
begin
if rising_edge(clk) then
i2sClocksDivider_i <= std_logic_vector(unsigned(i2sClocksDivider_i) + 1);
end if;
end process;
end rtl;
receiver.vhd
library IEEE;
entity i2sReceiver is
port(
serialClock : in std_logic;
wordSelect : in std_logic;
serialData : in std_logic;
lastSample : out std_logic_vector(23 downto 0) := (others => '0')
end i2sReceiver;
architecture rtl of i2sReceiver is
signal currentSample_i : std_logic_vector(23 downto 0) := (others => '0');
signal currentSampleIndex_i : std_logic_vector(5 downto 0) := (others => '0');
signal lastWordSelect_i : std_logic;
begin
process(serialClock)
begin
if rising_edge(serialClock) then
currentSampleIndex_i <= std_logic_vector(unsigned(currentSampleIndex_i) + 1);
if currentSampleIndex_i(4 downto 0) < "11000" then
currentSample_i(to_integer(unsigned(currentSampleIndex_i(4 downto 0)))) <= serialData;
end if;
if (lastWordSelect_i = (not lastWordSelect_i)) then
lastWordSelect_i <= wordSelect;
if lastWordSelect_i = '1' then
currentSampleIndex_i <= (others => '0');
end if;
end if;
end if;
if falling_edge(serialClock) then
if ((currentSampleIndex_i = "011100") or (currentSampleIndex_i = "111100")) then
lastSample <= currentSample_i;
end if;
end if;
end process;
end rtl;
transmitter.vhd
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity i2sTransmitter is
port (
serialData : out std_logic;
lastSample : in std_logic_vector(23 downto 0)
end i2sTransmitter;
architecture rtl of i2sTransmitter is
begin
begin
currentSampleIndex_i <= "000001";
end if;
end if;
end if;
currentSample_i(23 downto 0) <= lastSample;
end if;
serialData <= currentSample_i(to_integer(unsigned(currentSampleIndex_i(4 downto 0))));
end if;
end if;
end process;
end rtl;
top.vhd
library IEEE;
entity box is
port(
clk : in std_logic;
reset : in std_logic;
adcSerial : in std_logic;
mclkAdc : out std_logic;
sclkAdc : out std_logic;
lrclkAdc : out std_logic;
dacSerial : out std_logic;
mclkDac : out std_logic;
sclkDac : out std_logic;
lrclkDac : out std_logic
end box;
architecture Behavioral of box is
component clk_wiz_v3_6 is
port
clk_in1 : in std_logic;
end component;
component i2sClocks is
port
clk : in std_logic;
end component;
component i2sReceiver is
port(
end component;
component i2sTransmitter is
port(
end component;
signal mclk_i : std_logic;
signal sclk_i : std_logic;
signal lrclk_i : std_logic;
signal dacSerial_i: std_logic;
signal sample_i : std_logic_vector(23 downto 0);
begin
mclkAdc <= mclk_i;
sclkAdc <= sclk_i;
lrclkAdc <= lrclk_i;
mclkDac <= mclk_i;
sclkDac <= sclk_i;
lrclkDac <= lrclk_i;
dacSerial <= dacSerial_i;
clocks: clk_wiz_v3_6
port map
clk_in1 => clk,
mclk => mclk_i,
sclk => sclk_i,
reset => reset
clocks2: i2sClocks
port map
clk => sclk_i,
lrclk => lrclk_i
adc: i2sReceiver
port map
serialClock => sclk_i,
wordSelect => lrclk_i,
serialData => adcSerial,
lastSample => sample_i
dac: i2sTransmitter
port map
serialData => dacSerial_i,
end Behavioral;
constrains-clean.ucf
CONFIG VCCAUX = "3.3" ;
NET "clk" LOC = V10 | IOSTANDARD = LVCMOS33 | PERIOD = 100MHz;
NET "reset" LOC = C17 | IOSTANDARD = LVCMOS33 | DRIVE = 8 | SLEW = FAST | PULLUP;
NET "dacSerial" LOC = T11;
NET "sclkDac" LOC = T10;
NET "lrclkDac" LOC = V13;
NET "mclkDac" LOC = V11;
NET "adcSerial" LOC = H17;
NET "sclkAdc" LOC = H18;
NET "lrclkAdc" LOC = J18;
NET "mclkAdc" LOC = K16;
Build results
When clock divider from CORE Generator is connected to outputs (receiver), sythesis and implemetation are successful.
When clock divider from CORE Generator is connected to receiver's and transmitter's outputs, I get errors:
ERROR:ConstraintSystem:59 - Constraint <NET "sclkAdc" LOC = H18;> [constrains-clean.ucf(13)]: NET "sclkAdc" not found. Please verify that: 1. The specified design element actually exists in the original design. 2. The specified object is spelled correctly in the constraint source file. WARNING:ConstraintSystem - A target design object for the Locate constraint '<NET "sclkAdc" LOC = H18;> [constrains-clean.ucf(13)]' could not be found and so the Locate constraint will be removed. ERROR:ConstraintSystem:59 - Constraint <NET "mclkAdc" LOC = K16;> [constrains-clean.ucf(15)]: NET "mclkAdc" not found. Please verify that: 1. The specified design element actually exists in the original design. 2. The specified object is spelled correctly in the constraint source file. WARNING:ConstraintSystem - A target design object for the Locate constraint '<NET "mclkAdc" LOC = K16;> [constrains-clean.ucf(15)]' could not be found and so the Locate constraint will be removed.
When clock divider from CORE Generator is connected to receiver's and transmitter's outputs and to additional divider used to generate LRCLK, I get errors:
ERROR:ConstraintSystem:59 - Constraint <NET "sclkAdc" LOC = H18;> [constrains-clean.ucf(13)]: NET "sclkAdc" not found. Please verify that: 1. The specified design element actually exists in the original design. 2. The specified object is spelled correctly in the constraint source file. WARNING:ConstraintSystem - A target design object for the Locate constraint '<NET "sclkAdc" LOC = H18;> [constrains-clean.ucf(13)]' could not be found and so the Locate constraint will be removed. ERROR:ConstraintSystem:59 - Constraint <NET "mclkAdc" LOC = K16;> [constrains-clean.ucf(15)]: NET "mclkAdc" not found. Please verify that: 1. The specified design element actually exists in the original design. 2. The specified object is spelled correctly in the constraint source file. WARNING:ConstraintSystem - A target design object for the Locate constraint '<NET "mclkAdc" LOC = K16;> [constrains-clean.ucf(15)]' could not be found and so the Locate constraint will be removed. Done... Checking expanded design ... ERROR:NgdBuild:809 - output pad net 'sclkDac' has an illegal load: pin C on block clocks2/i2sClocksDivider_i_0 with type FD, pin C on block clocks2/i2sClocksDivider_i_1 with type FD, pin C on block clocks2/i2sClocksDivider_i_2 with type FD, pin C on block clocks2/i2sClocksDivider_i_3 with type FD, pin C on block clocks2/i2sClocksDivider_i_4 with type FD, pin C on block clocks2/i2sClocksDivider_i_5 with type FD, pin C on block clocks2/i2sClocksDivider_i_6 with type FD
When clock divider from CORE Generator is connected to receiver's and transmitter's outputs,to additional divider used to generate LRCLK and to I2S modules in project, I get errors:
WARNING:ConstraintSystem - A target design object for the Locate constraint '<NET "sclkAdc" LOC = H18;> [constrains-clean.ucf(13)]' could not be found and so the Locate constraint will be removed. ERROR:ConstraintSystem:59 - Constraint <NET "mclkAdc" LOC = K16;> [constrains-clean.ucf(15)]: NET "mclkAdc" not found. Please verify that: 1. The specified design element actually exists in the original design. 2. The specified object is spelled correctly in the constraint source file. WARNING:ConstraintSystem - A target design object for the Locate constraint '<NET "mclkAdc" LOC = K16;> [constrains-clean.ucf(15)]' could not be found and so the Locate constraint will be removed. WARNING:NgdBuild:1012 - The constraint <NET "sclkAdc" LOC = H18;> [constrains-clean.ucf(13)] is overridden on the design object sclkDac by the constraint <NET "sclkDac" LOC = T10;> [constrains-clean.ucf(8)].
To be honest, I spend a few days trying to solve it but with no luck. What should I do to succesfully connect clock divider from CORE Generator and build project without errors?
EDIT:
Thanks to @Paebbels, warnings about wordSelect
and currentSampleIndex_i_5
are no longer occuring. Following his advices, I changed design as follows:
- In constraints.ucf pin reset is assigned only to location and I/O standard and so does every other pin besides clk (i.e.
LOC = T10 | IOSTANDARD = LVCMOS33;
). currentSampleIndex
in both transmitter and receiver is now written as unsigned.currentSampleIndex
and every assignment or condition with it is trimmed to 5 bits- The condition in transmitter and receiver is now
if (wordSelect = (not lastWordSelect_i))
Fatal errors
Errors and warnings occuring durign compilation are now as follow:
Clock Information: ------------------ -----------------------------------+-----------------------------------+------ -+ Clock Signal | Clock buffer(FF name) | Load | -----------------------------------+-----------------------------------+-------+ clocks/clk1obuf | NONE(clocks2/i2sClocksDivider_i_0)| 7 | clocks/pll_base_inst/CLKOUT1 | BUFG | 1 | clocks/pll_base_inst/CLKOUT0 | BUFG | 1 | -----------------------------------+-----------------------------------+------ -+ INFO:Xst:2169 - HDL ADVISOR - Some clock signals were not automatically buffered by XST with BUFG/BUFR resources. Please use the buffer_type constraint in order to insert these buffers to the clock signals to help prevent skew problems. (...) ERROR:ConstraintSystem:59 - Constraint <NET "sclkAdc" LOC = H18 |> [constrains-clean.ucf(13)]: NET "sclkAdc" not found. Please verify that: 1. The specified design element actually exists in the original design. 2. The specified object is spelled correctly in the constraint source file. WARNING:ConstraintSystem - A target design object for the Locate constraint '<NET "sclkAdc" LOC = H18 |> [constrains-clean.ucf(13)]' could not be found and so the Locate constraint will be removed. ERROR:ConstraintSystem:59 - Constraint <IOSTANDARD = LVCMOS33;> [constrains-clean.ucf(13)]: NET "sclkAdc" not found. Please verify that: 1. The specified design element actually exists in the original design. 2. The specified object is spelled correctly in the constraint source file. ERROR:ConstraintSystem:59 - Constraint <NET "mclkAdc" LOC = K16 |> [constrains-clean.ucf(15)]: NET "mclkAdc" not found. Please verify that: 1. The specified design element actually exists in the original design. 2. The specified object is spelled correctly in the constraint source file. WARNING:ConstraintSystem - A target design object for the Locate constraint '<NET "mclkAdc" LOC = K16 |> [constrains-clean.ucf(15)]' could not be found and so the Locate constraint will be removed. ERROR:ConstraintSystem:59 - Constraint <IOSTANDARD = LVCMOS33;> [constrains-clean.ucf(15)]: NET "mclkAdc" not found. Please verify that: 1. The specified design element actually exists in the original design. 2. The specified object is spelled correctly in the constraint source file. Done... Checking expanded design ... ERROR:NgdBuild:809 - output pad net 'sclkDac' has an illegal load: pin C on block clocks2/i2sClocksDivider_i_0 with type FD, pin C on block clocks2/i2sClocksDivider_i_1 with type FD, pin C on block clocks2/i2sClocksDivider_i_2 with type FD, pin C on block clocks2/i2sClocksDivider_i_3 with type FD, pin C on block clocks2/i2sClocksDivider_i_4 with type FD, pin C on block clocks2/i2sClocksDivider_i_5 with type FD, pin C on block clocks2/i2sClocksDivider_i_6 with type FD
INFO:Xst:2261 - The FF/Latch <adc/currentSampleIndex_us_0> in Unit <box> is equivalent to the following FF/Latch, which will be removed : <dac/currentSampleIndex_us_0> INFO:Xst:2261 - The FF/Latch <adc/currentSampleIndex_us_1> in Unit <box> is equivalent to the following FF/Latch, which will be removed : <dac/currentSampleIndex_us_1> INFO:Xst:2261 - The FF/Latch <adc/currentSampleIndex_us_2> in Unit <box> is equivalent to the following FF/Latch, which will be removed : <dac/currentSampleIndex_us_2> INFO:Xst:2261 - The FF/Latch <adc/currentSampleIndex_us_3> in Unit <box> is equivalent to the following FF/Latch, which will be removed : <dac/currentSampleIndex_us_3> INFO:Xst:2261 - The FF/Latch <adc/currentSampleIndex_us_4> in Unit <box> is equivalent to the following FF/Latch, which will be removed : <dac/currentSampleIndex_us_4> INFO:Xst:2261 - The FF/Latch <adc/currentSampleIndex_us_5> in Unit <box> is equivalent to the following FF/Latch, which will be removed : <dac/currentSampleIndex_us_5> INFO:Xst:2261 - The FF/Latch <adc/lastWordSelect_i> in Unit <box> is equivalent to the following FF/Latch, which will be removed : <dac/lastWordSelect_i> (...) WARNING:ConstraintSystem - A target design object for the Locate constraint '<NET "sclkAdc" LOC = H18 |> [constrains-clean.ucf(13)]' could not be found and so the Locate constraint will be removed. ERROR:ConstraintSystem:59 - Constraint <NET "mclkAdc" LOC = K16 |> [constrains-clean.ucf(15)]: NET "mclkAdc" not found. Please verify that: 1. The specified design element actually exists in the original design. 2. The specified object is spelled correctly in the constraint source file. WARNING:ConstraintSystem - A target design object for the Locate constraint '<NET "mclkAdc" LOC = K16 |> [constrains-clean.ucf(15)]' could not be found and so the Locate constraint will be removed. ERROR:ConstraintSystem:59 - Constraint <IOSTANDARD = LVCMOS33;> [constrains-clean.ucf(15)]: NET "mclkAdc" not found. Please verify that: 1. The specified design element actually exists in the original design. 2. The specified object is spelled correctly in the constraint source file. WARNING:NgdBuild:1012 - The constraint <NET "sclkAdc" LOC = H18 |> [constrains-clean.ucf(13)] is overridden on the design object sclkDac by the constraint <NET "sclkDac" LOC = T10 |> [constrains-clean.ucf(8)]. WARNING:NgdBuild:1012 - The constraint <IOSTANDARD = LVCMOS33;> [constrains-clean.ucf(13)] is overridden on the design object sclkDac by the constraint <IOSTANDARD = LVCMOS33;> [constrains-clean.ucf(8)].
wordSelect
never used? Please see my extension in my answer. \$\endgroup\$
