I've been learning how to code for PIC 16f628A and I wrote a very simple code to turn on a LED, which is connected to RB0, and keep it on. My original intention was to use SDCC and GPUTILS to compile the projects. However, it seems that SDCC or GPUTILS are generating invalid hex files, since the program doesn't act as expected whenever I upload it to the chip, the LED keeps off during all the program execution. A similar code compiled with CSC's compiler runs without any problem. Also, I got no success in executing a simple program compiled with GPASM. It's noteworthy that GPSIM executes all those programs perfectly and shows the pins are working as expected. I'm using K150 as programmer. I don't know what is going on with SDCC and GPUTILS.
#include "pic16f628a.h"
//#include "tsmtypes.h"
//#include "tsmpic.h"
#include <stdint.h>
//CONFIG:__config (_CP_OFF & _LVP_OFF & _BOREN_OFF & _MCLRE_ON & _WDT_OFF & _PWRTE_ON & _INTOSC_OSC_NOCLKOUT)
uint16_t __at 0x2007 __CONFIG = _CP_OFF & _LVP_OFF & _BOREN_OFF & _MCLRE_ON & _WDT_OFF & _PWRTE_ON & _INTOSC_OSC_NOCLKOUT;
#define CLOCK_8MHZ 0
#define CLOCK_4MHZ 1
void main(void)
//SCS = 1;
TRISA = 0x00;
TRISB = 0x00;
#ifdef __16f628a // Only compile this section for PIC16f628a
CMCON = 0x07; /** Disable comparators. NEEDED FOR NORMAL PORTA
* BEHAVIOR ON PIC16f628a! */
#endif
// Loop forever.
while(1) {
RB0 = 1;
