I'm looking at some transistor radio circuits and the book I'm following makes the following statement with regard to AC gain: "By raising the DC voltage at the collector, the internal collector-base capacitances of the transistor are reduced".
Here's a circuit to help understand what's going on:
Here the author has killed the DC gain by placing an inductor in parallel with R2 whilst leaving the AC gain intact: collector reactance (L1||R2) / emitter reactance (C3||R3).
I have a reasonable grasp of the effect of Miller Capacitance on an inverting amplifier, where the inverted output acts negatively on the input. What I don't understand is why increasing the collector voltage acts to reduce collector-base capacitance.
Does the increase in current flowing through the collector-emitter junction have anything to do with it?
    \$\begingroup\$ What happens to the capacitance of a diode (PN junction) in reverse mode as a function of the (reverse) voltage ? This effect is used in varicap diodes but any PN junction exhibits this behaviour. \$\endgroup\$ Nov 5, 2015 at 13:07
  • \$\begingroup\$ I have no idea. But, if you turn your question into a fully fledged answer, you'll have made my day. \$\endgroup\$
    – Buck8pe
    Nov 5, 2015 at 13:18
  • \$\begingroup\$ Open your favorite textbook on semiconductor physics and look it up then ! If you want to be able to work with analog circuits, this is a thing you need to know and understand. It's not hard. \$\endgroup\$ Nov 5, 2015 at 13:19
  • \$\begingroup\$ Is this the same as the "Miller Effect", or is that only on FETs? I've never quite understood it either. \$\endgroup\$
    – pjc50
    Nov 5, 2015 at 13:45
    \$\begingroup\$ Thanks for the hint @FakeMoustache, a quick search for varactors gave me the intuition I needed. \$\endgroup\$
    – Buck8pe
    Nov 5, 2015 at 13:49
As @FakeMoustache hinted in a comment to your question, the explanation lies in the behavior of a reverse-biased PN junction, because that's what Q1's collector-base junction is in your circuit.
From a macroscopic point of view any reverse-biased PN junction acts like a parallel-plate capacitor whose capacitance (called transition capacitance \$C_T\$) depends inversely on the reverse voltage \$V_R\$. The relationship is not linear, but it is approximately:
$$ C_T = K \dfrac{1}{\sqrt{V_0 + V_R}} $$
where \$V_0\$ is the voltage gap created by the junction and \$K\$ is a constant.
EDIT
Struggling to remember the exact form of the formula (there are half a dozen of ways of writing down that relationship, depending on which physical parameters of the junction you want to emphasize) I found a more intuitive formula in this Google book:
$$ C_T = \dfrac{C_0}{(1 + V_R)^n} $$
Note: That formula has an error in it (dimensional analysis debunks it). Probably \$V_R\$ is meant to be the relative voltage with respect to some reference. I guess the correct formula should be: $$ C_T = \dfrac{C_0}{\left(1 + \dfrac{V_R}{V_0}\right)^n} $$
where \$C_0\$ is the capacitance when no bias is applied and \$n\$ depends on how the junction is doped: \$n = \frac 1 2\$ for step-graded junctions, whereas \$n=\frac 1 3 \$ for linearly-graded junctions.
Another interesting article on the subject (tougher semiconductor physics stuff) explains how to derive that relationship (in yet another form!).
    \$\begingroup\$ Yep, @FakeMoustache put me on the right track and for those interested the images in this link (en.wikipedia.org/wiki/Varicap) give you a fair idea of what's happening. \$\endgroup\$
    – Buck8pe
    Nov 5, 2015 at 13:52
  • \$\begingroup\$ Exactly :-) Ct goes down when Vr goes up ! The increased reverse voltage causes the size of the depletion layer to expand, this decreases the capacitance. Visualize it, now remember forever :-) \$\endgroup\$ Nov 5, 2015 at 13:53
