I'm using a cheap chinese XL6009 adjustable converter module to boost 5 V to 12 V. To test this converter, I used a 5 V supply, a 120 Ω ohm load to draw 100 mA current (100 mA at 12 V is the requirement of my target circuit), hooked up a DMM to monitor the voltage and an analog current meter in series with the load, and connected an oscilloscope across the load. It was drawing about 0.25 A from the source (a regulated lab supply), to give an efficiency of 96%, but the results were not particularly promising (here, V/div = 50 mV and T/div = 0.5 µs): V/div = 50 mV and T/div = 0.5 µs.
I housed the converter in a metal enclosure, and there was a definite improvement in the ripple characteristics (here, V/div = 10 mV and T/div = 0.5 µs): V/div = 10 mV and T/div = 0.5 µs
Even then, these 40 mV spikes will eventually kill the capacitors in my target circuit.
Just to test, I ramped up the boost converter to 15 V and then hooked it up to a 7812 with 1 m wires running from the enclosure of the converter to the breadboard on which I have my regulator. The input side filter capacitor is 470 µF and the output side one is 22 uF (I tried many combinations but it didn't make much difference). I can't embed more images directly, so it's here (V/div = 5 mV and T/div = 0.5 µs): https i imgur com M43un2W jpg (sorry).
What am I doing wrong and how can I fix it?
  • 4
    \$\begingroup\$ How are you probing the output voltage? To get a good measurement you can't use a ground lead. The best way is to make a coil around the ground barrel of the scope probe with some wire, do the same for the tip and solder both coils right across the output cap. Then insert the probe into the coils which are now formed to fit the probe. Then you can see what the real ripple is. \$\endgroup\$
    – John D
    Nov 5, 2015 at 16:17
  • \$\begingroup\$ If the linear regulator doesn't help, probably the noises are coming from the ground. Or your scope. \$\endgroup\$
    – Eugene Sh.
    \$\begingroup\$ Your first problem: A cheap "Chinese" boost converter.. \$\endgroup\$
    – Jasper
    Nov 5, 2015 at 16:18
    \$\begingroup\$ @Jasper not necessarily.. It is a potential problem. \$\endgroup\$
    – Eugene Sh.
    \$\begingroup\$ As JohnD and EugeneSh pointed out, the noise is probably partly due to the scope. If you have old BNC cables, cut one in half and solder the shield / signal right to the points on the circuit where you want to measure noise. This method will allow you to measure to a few mV with accuracy assuming the scope is good enough. \$\endgroup\$
    – MadHatter
    Nov 5, 2015 at 16:27
Only illustrating the comment of Mr. John D., I would suggest you to visit this link: http://www.edn.com/design/power-management/4411821/Testing-a-power-supply---Noise--Part-2--
Figure 1 (specially on the right) shows one of the best ways to measure ripple/noise.
Your first picture shows a noise frequency close to 12MHz. I guess that the 7812 won't be able to control or kill this frequency. Your option is to attenuate the noise before it arrives to the 7812 input.
Supposing that you will always use the 1m wire length and also always in the same position: the 1m wire is probably working as a transmission line. Twist the wires (in order to create a common mode inductor) and add 100nF ceramic chip capacitors between ground and positive of each side of the wire may help.
Hope this text can help you a little bit.
Best regards
As almost all of you said, it turned out to be noise from the ground and other external sources, and not the converter with a linear regulator.
I don't have access to real probes, just coax, so, as MadHatter suggested, I soldered the shield and signal directly to the output capacitor. The results were good (here, V/div = 5 mV and T/div = 0.5 µs): enter image description here
The top trace is from the directly soldered coax and the bottom one is using longer ground wires, so I can be pretty sure that the 7812 output is smooth enough.
Thanks everyone!
