I'm currently designing a pcb in EAGLE (v7.4) for a school project and I've included a potentiometer for gain control. However, I will not be placing the potentiometer directly on the board. I want to connect it with a wire to board 1x3 molex connector. This is my current schematic:
I would like to replace my molex connector symbol with a potentiometer symbol. Is there a way to place virtual components (and replace them with my connector)? This would make my schematic more readable.
Thanks
You should not do that.
The part that will be placed on the board is a connector.
If you gave the connector a potentiometer symbol, the layout designer would be surprised to find a connector footprint at that location. The people who build the board would be very confused when the part that arrived to be placed in that location turned out to be a connector. People debugging the board would be confused to find a connector there instead of a potentiometer, etc.
If you want the schematic to be clear, you should add the value of the pot to the text where you currently have "Off board potentiometer". If you really want a visible clue about the connections of the potentiometer, you could add a symbol, purely using drawing elements showing which pins connect to the ends and the wiper.
  • \$\begingroup\$ I always assumed my eagle schematic should be the same as the schematic I drew on paper (and later I would just change the footprint of the component). Thanks for clearing this up. \$\endgroup\$
    – Aether
    Nov 7, 2015 at 15:53
    \$\begingroup\$ While it's helpful to make the schematic clearly show the circuit operation for debugging, when you enter a schematic into a CAD tool (like Eagle) the main purpose is usually to communicate the design to the layout designer, so it is not a good idea to obscure the details that are important to them. \$\endgroup\$
    – The Photon
    Nov 7, 2015 at 15:56
