This is a question from someone who has just started to learn electronics. I'm a bit confused
Lets say I have a series circuit with three lamps. Lamp 1 needs 1V, lamp 2 needs 2V and lamp3 needs 3V. I therefore assume I need a 6V battery for this set up. However if I only have a 12V battery, presumably I would need to insert a resistor to reduce the voltage so given I need to 'remove' 6V from the circuit. This would then be 6/Current= Resistance. Do I assume that I would know the current from the battery and that this is the current throughout the circuit. Also does it matter where I put the resistor in relation to the lamps?
