I was studying for my Design of Analog Circuits course and I have two questions about this ADC. If someone can explain me why in the figure below in the Pipeline Analog to Digital Converter, why Vin is compared with Vref/2 instead of Vref and why after doing the summation, the result is multiplied by a gain of 2? What does that has to be with functionality of the ADC.
Pipeline ADC
  • \$\begingroup\$ If Vref is the full scale range, then above what voltage must the signal be for the MSB to be set? \$\endgroup\$ Nov 9, 2015 at 1:44
  • \$\begingroup\$ If Vin > Vref/2, then MSB = 1. If Vin < Vref/2, then MSB = 0. Why is that? Why comparing with Vref/2? \$\endgroup\$
    – EMPV
    Nov 9, 2015 at 1:58
    \$\begingroup\$ If you have to ask that, you need to go back to the very beginning and understand what an in general ADC does, more specifically how voltages map to binary codes. \$\endgroup\$ Nov 9, 2015 at 2:31
The comparison with vref/2 is because that is the place-value of the MSB of the ADC output.
the next bit has a value of 1/4 vref, so the difference value is doubled before comparison with vref/2
