Am I correct that to disable the reset pin of Attiny85, and use it as an IO pin, I need to disable the reset fuse bit(RSTDSBL)?
If so, should my RSTDSBL bit be 1 (assuming 1 = yes, disable)?
I am a little confused, because it looks like my reset pin got disabled only after I set the RSTDSBL bit to 0 (which is reverse of the logic I expected).
