I would like to replace a piezo igniter in a small project with something that can be electronically controlled (I have created some simple hairspray-powered foam rockets, and I would like to be able to sequence several of them from a computer).
It looks like pulse igniters, like this, are relatively inexpensive, but it's been hard to find any documentation or wiring diagrams for them and I'm unsure if I understand all the connections.
There are obvious inputs for power and for a switch, but on the high voltage side there are three wires, labelled HV1, HV2, and S. HV1 and HV2 appear to come off either end of a coil, and S is a mystery.
The igniter looks something like this:
Diagram of the igniter
And the innards look actually like this:
Inside of igniter
HV1 to HV2 seems to generate the most effective spark, but I don't know if that's using the igniter correctly or slowly frying its innards. Can someone help explain these labels?
    \$\begingroup\$ Don't buy anything without a proper datasheet. The manufacturer should know and should tell you. \$\endgroup\$ – PlasmaHH Nov 10 '15 at 21:08
  • \$\begingroup\$ If these are what I think they are, they begin sparking as soon as power is applied \$\endgroup\$ – Daniel Nov 10 '15 at 22:09
  • \$\begingroup\$ They have a switch connection which must be closed before they will spark. The question is primarily about the outputs (HV1, HV2, and S), and what exactly each one is for. \$\endgroup\$ – larsks Nov 10 '15 at 23:11
Re the gas igniter drawing - We use these very same igniters in our gas water heaters. The questionmarks in question - connects to a soleniod valve that opens the gasflow when the water valve is opened.
white green black for gas valve (solenoid valve). S for flame out sensor. HV1 and HV2 for sparking pins
HV1=High Voltage 1 HV2=High Voltage 2 - these are the amplified outputs to create the sparks S=Switch - this is the temperature probe so it knows if the flame is on or off
