11
Some headphones are 'active', with amplifiers built into the cups and requiring a power source (typically AAA batteries).
I then see many audiophiles discussing frequency response as a metric of how good headphones are, and they categorically dismiss most 'active' headphones such as the Dre Beats Studio.
However, with some op amps it would seemingly be fairly easy to equalize the input signal, pre-amplified, such that it could completely correct for the driver's frequency response and thus produce an extremely flat frequency response if desired (or not, such as bass boost or cut).
Is there something particularly difficult with doing so?
Frequency Response Graph http://graphs.headphone.com/graphCompare.php?graphType=0&graphID[]=1383&graphID[]=193&graphID[]=1263&graphID[]=853&scale=20
For example, for the Dre Beats Studio (blue line), perhaps the EQ circuit could provide +3db@750Hz, -5dB@1100Hz, +6.5dB@1300Hz, +5dB@1550Hz, -4.5dB@8.5kHz, and +14dB@15kHz, with the slopes tuned to best align the frequency response to 0db from 500Hz to 20kHz.
20
When you put something to your ear reproducing standard stereo recordings, you don't want a flat frequency response because the head-related transfer function that normally comes into play for a sound source much further away looks very different when the source is against your ear.
Let me quote you a couple of paragraphs from a book:
Of all the components in the electroacoustic transmission chain, headphones are the most controversial. High fidelity in its true sense, involving not only timbre but also spatial localization, is associated more with loudspeaker stereophony due to the well-known in-head localization of headphones. And yet binaural recordings with a dummy head, which are the most promising for true-to-life high fidelity, are destined for headphone reproduction. Even in their heyday they found no place in routine recording and broadcasting. At that time the causes were unreliable frontal localization, incompatibility with loudspeaker reproduction, as well as their tendency to be unaesthetic. Since digital signal processing (DSP) can filter routinely using binaural head-related transfer functions, HRTF, dummy heads are no longer needed.
Still the most common application of headphones is to feed them with stereo signals originally intended for loudspeakers. This raises the question of the ideal frequency response. For other devices in the transmission chain (Fig. 14.1), such as microphones, amplifiers and loudspeakers, a flat response is usually the design objective, with easily definable departures from this response in special cases. A loudspeaker is required to produce a flat SPL response at a distance of typically 1 m. The free-field SPL at this point reproduces the SPL at the microphone location in the sound field of, say, a concert being recorded. Listening to the recording in front of a LS, the head of the listener distorts the SPL linearly by diffraction. His ear signals no longer show a flat response. However, this need not concern the loudspeaker manufacturer, since this would also have happened if the listener had been present at the live performance. On the other hand, the headphone manufacturer is directly concerned with producing these ear signals. The requirements laid down in the standards have led to the free field calibrated headphone, whose frequency response replicates the ear signals for a loudspeaker in front, as well as the diffuse field calibration, in which the aim is to replicate the SPL in the ear of a listener for sound impinging from all directions. It is assumed that many loudspeakers have incoherent sources each with a flat voltage response.
(a) Free-field response: For want of any better reference, the various international and other standards have set up the following requirement for high-fidelity headphones: the frequency response and perceived loudness for a constant voltage mono signal input is to approximate that of a flat response loudspeaker in front of the listener under anechoic conditions. The free-field (FF) transfer function of a headphone at a given frequency (1000 Hz chosen as 0 dB reference) is equal to the amount in dB by which the headphone signal is to be amplified to give equal loudness. Averaging over a minimum number of subjects (typically eight) is required. [...] Figure 14.76 shows a typical tolerance field.
(b) Diffuse-field response: During the 1980s there began a movement to replace the free-field standard requirements with another, where the diffuse field (DF) is the reference. As it turned out, it has made its way into the standards, but without replacing the old one. The two now stand side by side. The dissatisfaction with the FF reference arose principally from the magnitude of the 2 kHz peak. It was held responsible for coloration of the image, since frontal localization is not achieved even for a mono signal. The way in which the hearing mechanism perceives coloration is described by the association model of Theile (Fig. 14.62). A comparison of the ear responses for diffuse field and free field is shown in Fig. 14.77. [...] Since the subjective listening test is the one that counts, FF headphones have so far been more the exception than the rule. A palate of different frequency responses is available to cater for individual preferences, and each manufacturer has its own headphone philosophy with frequency responses ranging from flat to free field and beyond.
This HRTF difference issue is also why angled drivers (in headphones) sound better to enough people that companies like Sennheiser sell such. Angled drivers don't fully make headphones sound like speakers though.
At factory or in a lab an artificial ear is used when measuring the frequency response. The one below is a lab-level one; the factory-level ones are a bit more simple.
I also found the methodology used by that HeadRoom site:
How we test frequency response: To perform this test we drive the headphones with a series of 200 tones at the same voltage and of ever increasing frequency. We then measure the output at each frequency through the ears of the highly-specialized (and pricey!) Head Acoustics microphone. After that we apply an audio correction curve that removes the head-related transfer function and accurately produces the data for display.
The microphone used is probably this one. It seems they actually invert the transfer function of the dummy head/ears via software because they say right before that that "Theoretically, this graph should be a flat line at 0dB."... but I'm not entirely sure what they do... because after that they say "A “natural sounding” headphone should be slightly higher in the bass (about 3 or 4 dB) between 40Hz and 500Hz." and "Headphones also need to be rolled-off in the highs to compensate for the drivers being so close to the ear; a gently sloping flat line from 1kHz to about 8-10dB down at 20kHz is about right." Which doesn't quite compile for me in relation to their previous statement about inverting/removing the HRTF.
Looking at some certificates that people got from the manufacturer (Sennheiser) for the headphone model (HD800) used in that HeadRoom example, it seems that HeadRoom displays the data without any assumed correction model for the headphone itself (which would explain why they give their later interpretation suggestions, so their initial "flat" suggestion is the misleading one), whereas Sennheiser uses DF (diffuse field) correction so their graphs look almost flat.
This is just a guess though, differences in measurement equipment (and/or between headphone samples) could well account for those differences since they aren't that big.
Anyway, this is an area of active and ongoing research (as you probably guessed from the last sentences quoted above about DF). There's quite a bit of this done by some HK researchers; I don't have (free) access to their AES papers, but some fairly extensive summaries can be read on the innerfidelity blog 2013, 2014 as well as following links from the main HK author's blog, Sean Olive; as shortcut, here are some free slides from their most recent (Nov 2015) presentation found there. This is quite a bit of material... I have only look at it briefly, but the theme seems to be that DF isn't good enough.
Here are a couple of interesting slides from one of their earlier presentations. First, the full frequency response (not truncated to 12KHz) of HD800 and on more clearly disclosed equipment:
And perhaps of most interest to the OP, the bassy sound of the Beats isn't all that appealing, granted in comparison with headphones that cost four to six times as much.
  • \$\begingroup\$ I disagree with your book where it says "And yet binaural recordings with a dummy head, which are the most promising for true-to-life high fidelity, are destined for headphone reproduction. Even in their heyday they found no place in routine recording and broadcasting." Every live televised sporting event that I have worked at uses a "holophone" mic array to capture ambient sound for use in the surround-sound audio mix. www.holophone.com \$\endgroup\$ Nov 11, 2015 at 12:36
  • \$\begingroup\$ @DwayneReid: Interesting. Is the ultimate target of that recording headphones though or is it 5.1 or 7.1 surround with speakers? There is also tech to downmix 5.1/7.1 to headphones, but I haven't gotten into that here. \$\endgroup\$
    – Fizz
    Nov 11, 2015 at 14:41
  • \$\begingroup\$ Well, the product advertised on their main page says "is the only patented microphone specifically designed for capturing discrete 7.1 channels of surround sound" so the "unbelievably lifelike 3-D audio playback experience over speakers or stereo headphones" probably uses a downmixing method (from 7.1) for headphones. \$\endgroup\$
    – Fizz
    Nov 11, 2015 at 14:47
  • \$\begingroup\$ Thank you, this answer has been really informative. Am I summarizing properly to say: headphone frequency response is trying to emulate the distortion that would be created from a frontal audio source diffusing around your face and into your ear canals, and a perfectly flat frequency response would sound 'unnatural'? \$\endgroup\$
    – Ehryk
    Nov 11, 2015 at 22:41
  • \$\begingroup\$ It's still a little unclear in that if they're applying the inverse transformation, then the goal would again be a flat 0dB line across the entire frequency spectrum, which in theory could be put in via an equalizer (ideally pre-amplification). Any thoughts on why active headphone makers aren't doing this to have a flat-0dB curve post-head-distortion correction, or perhaps selling dedicated headphone amps with them that apply this EQ like the Sennheiser Orpheus, but perhaps for less than $30k? They would seemingly be the ideal headphones then... \$\endgroup\$
    – Ehryk
    Nov 11, 2015 at 23:05
The simple answer is that a flat frequency response system constructed with op-amps to correct the driver response will necessarily have a very un-flat phase response in the pass band. This non-flatness means component frequencies of transient sounds become unevenly delayed, resulting in a subtle transient distortion which prevents proper sound component recognition, which means fewer distinct sounds can be discerned.
Consequently, It sounds terrible. As if all the sound is coming from a fuzzy ball centred exactly between one's ears.
The HRTF issue in the answer above is only part of this - the other is that a realizable analogue domain circuit can only have a causal time response, and to correct the driver properly one needs an acausal filter.
This can be approximated digitally with a driver-matched Finite Impulse Response filter, but this requires a small time delay which is enough to make movies very jarringly out-of-sync.
And it still sounds like it's coming from inside your head, unless the HRTF is also added back in too.
So, it's not so simple after all.
To make a "transparent" system, you don't need merely a flat pass band over the human hearing range, you also need a linear phase too - a flat group delay plot - and there is some evidence to suggest that this linear phase needs to continue up to a surprisingly high frequency so that directional cues are not lost.
This is easy to verify by experiment: Open a .wav of some music you are familiar with in a sound file editor like Audacity or snd, and delete one single 44100 Hz sample from just one channel, and realign the other channel so that the first sample now happens with the second one of the edited channel, and play it back.
You will hear a very noticeable difference, even though the difference is a time delay of only 1/44100th of a second.
Consider this: sound goes about 340 mm / ms, so at 20 kHz this is a time error of plus minus one sample delay, or 50 microseconds. That's 17 mm of sound travel, yet you can hear the difference with that missing 22.67 microseconds, which is only 7.7 mm of sound travel.
The absolute cut-off of human hearing is generally regarded to be around 20 kHz, so what's happening?
The answer is that hearing tests are conducted with test tones which mostly consist of just one frequency at a time, for a fairly long time at each part of the test. But our inner ears consist of a physical structure that performs an FFT of sorts on the sound while exposing neurons to it, so that neurons at different positions correlate to different frequencies.
Individual neurons can only re-fire so fast, so in some cases a few are used one-after-the-other to keep up... but this only works up to about 4 kHz or so... Which is right where our perception of tone ends. Yet there's nothing in the brain to stop a neuron firing just any time it feels so inclined, so what's the highest frequency that matters?
The point is that the tiny phase difference between the ears is perceptible, but rather than changing how we identify sounds (by their spectrographic structure) it affects how we perceive their direction. (which the HRTF also changes!) Even though it seems like it should be "rolled off" out of our range of hearing.
The answer is that the -3dB or even -10dB point is still too low - you need to go to about the -80 dB point to get it all. And if you want to handle loud sound as well as quiet, then you need to be good down to better than -100 dB. Which a single tone listening test is unlikely to ever see, largely because such frequencies only "count" when they arrive in phase with their other harmonics as part of a sharp transient sound - their energy in this case adds together, reaching enough of a concentration to trigger a neural response, even though as individual frequency components in isolation they may be too small to count.
Another issue is that we're constantly bombarded by many sources of ultrasonic noise anyway, probably much of it from broken neurons in our own inner ears, damaged by excessive sound level at some prior point in our lives. It would be hard to discern the isolated output tone of a listening test over such loud "local" noise!
This therefore requires "transparent" system design to use a much higher low-pass frequency so that there is space for the human low-pass to fade out (with it's own phase modulation which your brain is already "calibrated" to) before the system phase modulation starts changing the shape of transients, and shifting them around in time such that the brain can't recognise which sound they belong to any more.
With headphones it is far easier to simply construct them to have a single broadband driver with sufficient bandwidth, and rely upon the very high natural frequency response of the 'uncorrected' driver to prevent temporal distortion. This works far better with earphones, as the small mass of the driver lends itself well to this condition.
The reason for needing phase linearity is deeply rooted in the time-domain frequency-domain duality, as is the reason you can't construct a zero-delay filter that can "perfectly correct" any real physical system.
The reason it's "phase linearity" that matters and not "phase flatness" is because the overall slope of the phase curve doesn't matter - by duality, any phase slope is just equivalent to a constant time delay.
Everyone's outer ear has a different shape, and thus a different transfer function occurring at slightly different frequencies. Your brain is used to what it has, with it's own distinct resonances. If you use the wrong one, it will actually just sound worse, as the corrections your brain is used to doing will no longer correspond to the ones in the earphone's transfer function, and you will have something worse than a lack of cancellation of resonance - you'll have twice as many unbalanced poles/zeros cluttering up your phase delay, and utterly mangling your group delays and component arrive time relationships.
It will sound very unclear, and you won't be able to make out the spatial imaging encoded by the recording.
If you do a blind A/B listening test, everyone will select the uncorrected headphones which at least don't mangle the group delays so much, so that their brains can retune themselves into them.
And this is really why active headphones don't try to equalise. It's just too hard to get right.
It's also why digital room correction is the niche it is: Because using it properly requires frequent measurements, which are hard/impossible to do live, and which consumers generally don't want to know about.
Mostly because the acoustic resonances in the room under correction, which are mostly part of the bass response, keep shifting slightly as the air pressure, temperature and humidity all change, thus changing the speed of sound slightly, thus changing the resonances away from what they were when the measurement was taken.
  • \$\begingroup\$ Filtering in the F domian does cause phase distortion .All pass phase equalisation can be used to offset this .IN theory digital or analog can have good phase .Digital these days gives better flexability. \$\endgroup\$
    – Autistic
    Nov 13, 2015 at 8:00
  • \$\begingroup\$ Ah, thank you. This makes it clear why it isn't done in the active headphones that are passed analogue signal (wired headphones). This seemingly leaves the possibility open, then, for the levels to be adjusted in real time with no phase distortion either digitally on the source (like a computer or phone) or digitally on wireless headphones without any delay; is this still open as a feasibility for a 'perfectly flat' (post HRTF) response? \$\endgroup\$
    – Ehryk
    Nov 14, 2015 at 8:06
  • \$\begingroup\$ No. There must be some delay. Otherwise you literally need a time machine, since the only way to correct the phase of a real (causal) system, without adding any delay, would be to use a filter with the exactly reversed, anti-causal time response. And this means it necessarily needs to know the "future" of the signal before it lands at time = 0. \$\endgroup\$
    – RGD2
    Mar 3, 2016 at 1:03
-1
An interesting article and discussion. We tend to think the Nyquist theorem is a rule that applies everywhere, and we then find out that it doesn't. You measure the limit of human hearing to 20kHz using sine waves, and then sample at 44.1 or 48 kHz with the confidence that you've captured everything that the ear can hear. Yet shifting one channel by one sample causes significant change evwn though the difference, temporally, is above 20kHz.
In moving images, we think the eye integrates images with a frame rate above 20 frames per second. So film is shot at 24fps and played back with a 2x shutter to reduce flicker (48fps); TV is 50 or 60 Hz frame rate depending on region. Some of us can see 50 Hz frame rate flicker, especially if we've grown up with 60 Hz. But here's where it get's interesting. At the Hollywood Professional Association Tech Retreat and SMPTE conferences over the past few years, it's been shown that an average viewer sees a significant improvement in quality when the native frame is extended from 60 Hz to 120 Hz. Even more surprising, the same viewers saw a similar improvement when increasing the frame rate from 120 to 240 Hz. Nyquist would tell us that if we can't see the frame rate at 24, we only need to double the frame rate to guarantee capturing all that the eye can resolve; yet here we are at 10x the frame rate and still observing noticeable differences.
Clearly there's more going on here. In the case of motion imaging, the motion in the image impacts the frame rate required. And in audio, I would expect the complexity and density of the soundscape determines the needed audio resolution. All of those sounds depend far more on their phase coherence than frequency response to provide the articulation needed for imaging.
  • \$\begingroup\$ I fail to find anything here that answers the question. What does sample rate and the Nyquist sampling theorem have to do with headphone equalization? \$\endgroup\$
    – pipe
    Aug 4, 2016 at 7:53
  • \$\begingroup\$ There is no ADC in humans. Human hearing\vision doesn't "sample" anything, it uses neurons which are a kind of a mix between analog and digital and are practically continuous. The ear has a physical cutoff. Visual perception is also limited by how fast the brain can process information. \$\endgroup\$
    – Voltage Spike
    Aug 4, 2016 at 18:15
