I should consider many specific values for a circuit's parameters and simulate the circuit in each case by PSpice to get output files. Because of high number of required simulation, I am searching a way to automate this process. Would you please help me?
  • \$\begingroup\$ UTFG parametric analysis. Or statistical analysis in case there is greater number of parameters. \$\endgroup\$
    – venny
    Commented Nov 11, 2015 at 6:54
The term is "parametric analysis". There are many examples online, or you can just look at the manual here in Chapter 11.
