Is there such a thing? I would like to put my board in a box to isolate it from radiated emissions externally and also limit emissions from the board to the outside. I would also like a transparent window. Is this possible? [Thinking conductive coating, fine mesh etc]
  • 4
    \$\begingroup\$ Ever had a look into a microwave oven? \$\endgroup\$ – PlasmaHH Nov 12 '15 at 14:32
    \$\begingroup\$ Pay someone else to do it? I doubt those things exist as ots boxes where you can put anything in, but a lot of equipment is build that way, e.g. many network analyzers I had in hands. And if you need just one, its not a big job to cut a hole into some existing shielded box and glue some mesh over it. \$\endgroup\$ – PlasmaHH Nov 12 '15 at 14:50
    \$\begingroup\$ You could get an enclosure with a window and cover the window with a conductive transparency - that amount of effort does not seem large. Not sure how widespread these are in distribution. \$\endgroup\$ – Peter Smith Nov 12 '15 at 15:03
    \$\begingroup\$ Google "Indium tin oxide coated glass". \$\endgroup\$ – EM Fields Nov 12 '15 at 16:30
    \$\begingroup\$ Wire mesh will be cheaper than ITO. \$\endgroup\$ – mkeith Nov 12 '15 at 16:47
