I'm still new to all this stuff, but I'm slowly trying to understand. I'm getting most of my information from "Getting Started in Electronics" (Forrest Mimm's book)
Okay, so MOSFETs allow current to pass through the source and drain if positive current is flowing through the base. Am I correct?
FETs do the same thing, but it's when a negative current is applied to the base. Is this correct? (It showed a chart with negative current flowing to the base, basically stopping any current from the source to the drain.)
First of all: Negative current going to the base. How would you set this up?
Also, I don't really understand how a bipolar transistor differs from these other two? Is it just that a bipolar transistor is the same as a MOSFET, but only has an OFF and an ON, rather than a OFF, "some", and "full current"? Sorry, I'm a HUGE newbie at this stuff, but I'm just trying to "get it".
Also, I'm not really sure what a Transistor Amplifier does, or what purpose it serves.
  • 9
    \$\begingroup\$ Get a better book. The Art of Electronics is excellent. \$\endgroup\$ – Leon Heller Sep 26 '11 at 17:32
    \$\begingroup\$ Yeah, I don't like that book. \$\endgroup\$ – endolith Sep 26 '11 at 19:53
  • \$\begingroup\$ @Leon, Art of Electronics seems like more of an "Advanced" level, im still in beginner land. \$\endgroup\$ – user3073 Sep 26 '11 at 22:18
  • \$\begingroup\$ @Sauron: Have you tried reading it? amazon.com/gp/reader/0521370957/ref=sib_dp_ptu#reader-link \$\endgroup\$ – endolith Sep 27 '11 at 1:54
  • \$\begingroup\$ @endolith , Not yet.....thats just what i've been told. That it's the book after you've learned the basics. \$\endgroup\$ – user3073 Sep 27 '11 at 16:22
19
Now you know why I don't like this book.
Basic differences between a MOSFET and a FET
A MOSFET is a type of FET. It stands for "metal oxide semiconductor field effect transistor". All MOSFETs are FETs, not all FETs are MOSFETs. But the term is so common that things that are not actually MOSFETs are still called "MOSFETs", so there isn't really much difference; the terms are kind of interchangeable.
FET's do the same thing? But it's when a negative current is applied to the base?
No way, man. FETs don't have bases, they have gates. And gates do not pass current. The "metal oxide" part means that the gate is actually an insulator. No current can flow through the gate unless it's been destroyed. FETs are activated by a voltage on the gate, not a current. The connection is made by capacitance, by an electric field that reaches through the insulator, which is why they're called "field effect transistors".
When you apply a high enough voltage to the gate (relative to the source), the path from source to drain becomes a short circuit, just like a closed switch. When the voltage at the gate is low, the drain-to-source is not connected, like an open switch.
First of all — negative current going to the base — how would you set this up?
Yeah, this confused me when I read this book as a kid, too. Don't think of current in terms of electrons. No one in engineering does. Get a better book and learn about conventional current, which is a flow of imaginary positive charges used to simplify equations and abstract away the charge carriers (which can be electrons, holes, ions, or even protons). Conventional current flows into the base from a higher voltage.
Also, I'm not really sure what a Transistor Amplifier does?
Transistors are not amplifiers, despite what you read in books like this. Transistors are like valves that can be opened and closed electronically. You can use this property to build transistor amplifiers. If you connect it to a power source, you can amplify signals, or switch things on and off, etc.
I think the switch function of FETs should be taught first, since it's the easiest to understand (high voltage → closed switch, low voltage → open switch), then the variable valve amplifier function, then the same functions with BJTs. But books and coursework tend to go in chronological order of when they were first manufactured, which makes no sense to me. FETs were actually invented before the first BJT was manufactured, because they're conceptually simpler.
    \$\begingroup\$ Ya.....I think I just need a better book lol. \$\endgroup\$ – user3073 Sep 26 '11 at 22:19
    \$\begingroup\$ Anytime someone calls a non-MOSFET a MOSFET they are just plain wrong. If the context is important the error should be noted. Just as LASER is never spelt LAZER, or a Guitar is never called a Sitar - except when it's a Variax 700 :-) \$\endgroup\$ – Russell McMahon Sep 27 '11 at 14:38
    \$\begingroup\$ @RussellMcMahon: As Wikipedia says "The 'metal' in the name is now often a misnomer because the previously metal gate material is now often a layer of polysilicon (polycrystalline silicon)." so it's pretty common \$\endgroup\$ – endolith Sep 27 '11 at 15:24
6
No, you are confused. FETs are controlled by voltage on the gate. The gate does not draw current, which is to say it is high impedance. In a MOSFET there is actually a layer of silicon dioxide beteen the gate and the channel. In other FETs the gate is a reverse biased junction to the channel.
Bipolars differ in that they are controlled by current thru the base. I remember writing a more detailed answer on this a week or two ago. Perhaps some searching will uncover it.
Both types of transistors can be used as switches or in partially on mode. That depends on the circuit.
  • \$\begingroup\$ Ya I meant voltage, I always get voltage/current confused. I need to edit that. \$\endgroup\$ – user3073 Sep 26 '11 at 17:37
    \$\begingroup\$ @Sauron: You need to stop getting them confused. That's like confusing air with water. Get a better understanding of current and voltage. \$\endgroup\$ – endolith Sep 26 '11 at 19:59
  • \$\begingroup\$ @endolith, I think I just need a better book I don't think the book explained things very well. \$\endgroup\$ – user3073 Sep 26 '11 at 22:19
MOSFETs allow current to flow from their drain to source when there is "enough" voltage present at the gate - this voltage is reference to the MOSFET's source. This "enough" voltage is formally known as the Threshold voltage. When the voltage at the gate exceeds the threshold voltage of the MOSFET, the MOSFET is said to be on. Note that the threshold voltage is referenced to source. Keep this in mind as sometimes the source is not connected to ground.
In the following circuit when the voltage at the gate, V(GS), is higher than the threshold voltage the LED will turn on.
This is because when the MOSFET is off, it has a very high resistance between its drain and source. Think of this as a switch in the open position. In this case, most of the voltage from the supply also drops on the MOSFET itself.
If you increase V(GS) slowly starting from 0V, you'll notice that at a certain value the LED lights up. That is your threshold voltage. If you keep increasing your V(GS), the LED will increase in brightness - this is because the MOSFET's resistance is dropping and it's allowing more and more current to pass. Eventually, you'll notice that the LED brightness does not increase no matter how much you increase V(GS). This is because the MOSFET's resistance no longer determines the current (it's your 390 Ohm resistor).
If you increase V(GS) to some large value, like, say 12V you'll notice that now most of the voltage now drops across the 390 Ohm resistor and around 2V is dropped on the LED. This is because the MOSFET's resistance is almost zero now and it's now operating in the linear region.
FWIW
MOSFET = Metal Oxide Semiconductor Field Effect Transistor.
Regardless of what the gate material is, the term is important because it tells you some important hings about the nature of the transistor.
A MOSFET, as opposed to some other types of FET which may have some but not all of these attributes.
  • Has an essentially infinite resistance between it's controlling "gate" terminal and the rest of the universe.
  • Has a built in reverse polarity diode across its drain and source terminals. This is a feature of how it is constructed and is not avoidable with the materials commonly used. It can be avoided if you build your semiconductors on a Sapphire base (same material as used in jewelery) but this is expensive and not very common.
  • Can control current in either direction from drain to source when the gate is driven to its on state.
So, if people call junction FETs MOSFETS or call IGBT's MOSFETS or call small green tin hats with a feather MOSFETs they aren't and they shouldn't.
As for whether silicon, whose oxide is often used as a gate material for MOSFETs, is a metal - the pedants may if it makes life easier call the devices
    Metalloid oxide Semiconductor field effect transistors.
Silicon has properties of metals, non metals and semiconductors. It is commonly referred to as a metalloid, although even that is not consistent. The semiconductor industry has no doubt - which is strange as they should care more than most. They commonly call it "silicon metal".
Wikipedia Silicon
Wikipedia Metalloid
Sample of Silicon metal sellers - doesn't make them right. And
[Even the great Dow Corning call it silicon metal. Doesn't make ...
Metal / metalloid comment
Light relief - something made of "real" metal
FWIW, here are images of silicon from some of the 890,000 or so web pages that use the term "silicon metal". That doesn't make them correct, but shows how common the term is.
Many more "silicon metal" images here - each image hotlinks to a related web page.There are about 70,000 webpages (says Google) that have the term Silicon Metal associated with an image.
  • \$\begingroup\$ With regard to the drain-source diode, I think that could be avoided if there were a separate connection for the substrate and they were constructed out in a fashion similar to the MOSFETs in a typical NMOS or CMOS IC (whose substrates are all tied to VDD even though none of the other "terminals" are). The performance of MOSFETs which are constructed in such fashion, however, is not as good as the performance which can be achieved with more "three-dimensional" structures, and such layouts are not as amenable to having a separate substrate connection. \$\endgroup\$ – supercat Sep 2 '13 at 18:23
  • \$\begingroup\$ Your comments about silicon apply only to the intrinsic (pure elemental) material, which as you know is not used as-is in MOSFETs. If a semiconductor is degenerately doped, its electronic properties converge on those of a metal, and calling it a metal is entirely justifiable for applications that employ that behavior. And "silicon metal" is a specific thing: an alloy, also known as metallurgical grade silicon. It is not a term for pure elemental silicon. \$\endgroup\$ – Oleksandr R. Apr 21 '16 at 23:04
  • \$\begingroup\$ @OleksandrR. 4+ years on .... :-). | I don't think it's too important, but it does not seem that you have fully followed my comments on silicon. I thought I had suggested that exact terminology varied with use and perspective and that there are differences of opinion over terminology and in nature in each case. |The Wikioediaarticle , which I and you both cite, uses "silicon metal " as a term for an alloy of up to 5% impurity not because ADDING the impurity makes it into te described substance, but because they accept the term with UP TO about 5% impurity added. ie anyonw who wanted to .... \$\endgroup\$ – Russell McMahon Apr 23 '16 at 7:33
  • \$\begingroup\$ ... to use the term "Silicon Metal" for 4% impure silicon would be no less comfortable using it for 1% pur or 0.1% pure. ie its just an inexact trade term for "somewhat impure silicon". | If we really want to party we could start on "Hydrogen metal" and gaseous Hydrogen metal :-) - (just as we would not be offended in principle by eg "gaseous Iron metal" - even though the usage is unfamiliar. But, as I noted above, I don't think it's very important (as the whole area is rather imprecise).. \$\endgroup\$ – Russell McMahon Apr 23 '16 at 7:38
  • \$\begingroup\$ Isolated atoms/gases aren't a metal, even if they're made of an element that is metallic in its standard form; metallic hydrogen probably exists inside Jupiter. As a physicist I'm not comfortable with the idea that one can declare something a metal or not by inspection based on the position of its constituents in the periodic table. Metals can be made of non-metallic elements, and vice versa. But I don't think it's helpful to suggest that it's "imprecise" or all a matter of perspective, either. It is really very well defined--you only have to look at the interaction between the electrons. \$\endgroup\$ – Oleksandr R. Apr 23 '16 at 15:35
