I´m trying to save some data to flash memory on my STM32F407 board. Before I can save them, I need to erase a memory sector. I chose 16 Kbytes Sector1 starting with address 0x08004000 and chose Voltage range 2.1-2.7 V. I'm using HAL library.
Program stops responding after FLASH->CR |= FLASH_CR_STRT; line inside HAL_FLASHEx_Erase() -> FLASH_Erase_Sector() function.
I'm pretty sure it's my fault but I can't find out what is wrong.
HAL_FLASH_Unlock();
__HAL_FLASH_CLEAR_FLAG(FLASH_FLAG_EOP | FLASH_FLAG_OPERR | FLASH_FLAG_WRPERR |
                           FLASH_FLAG_PGAERR | FLASH_FLAG_PGPERR | FLASH_FLAG_PGSERR);
FLASH_EraseInitTypeDef EraseInitStruct;
EraseInitStruct.Sector = FLASH_SECTOR_1;
EraseInitStruct.TypeErase = TYPEERASE_SECTORS;
EraseInitStruct.VoltageRange = FLASH_VOLTAGE_RANGE_2;
EraseInitStruct.NbSectors = 1;
uint32_t SectorError = 0;
if (HAL_FLASHEx_Erase(&EraseInitStruct, &SectorError) != HAL_OK) {
    HAL_FLASH_Lock();
    return;
uint16_t data = 300;
//----------------------------write data
if (HAL_FLASH_Program(TYPEPROGRAM_WORD, start_address, data) != HAL_OK) {
    HAL_FLASH_Lock();
    return;
HAL_FLASH_Lock();
Did I choose wrong voltage range or number of sectors?
Thanks for your answers.
    \$\begingroup\$ Define "stops responding". Are you trying to debug through this? Don't expect that to work, as flash programming has tight hardware requirements. \$\endgroup\$ Nov 15, 2015 at 22:19
  • \$\begingroup\$ I placed my breakpoint on line with HAL_FLASH_Program() function but my program has never reached it. After erasing memory it stops responding and I can wait how long I want. \$\endgroup\$
    – Jardo421
    Nov 16, 2015 at 9:59
I found the solution. I used HAL_FLASH_Lock() function instead of HAL_FLASHEx_Erase() function and it works fine. I also changed SECTOR because I was accidently erasing my program.
unit32_t address = 0x0800C000;
HAL_FLASH_Unlock();
__HAL_FLASH_CLEAR_FLAG(FLASH_FLAG_EOP | FLASH_FLAG_OPERR | FLASH_FLAG_WRPERR | FLASH_FLAG_PGAERR | FLASH_FLAG_PGPERR | FLASH_FLAG_PGSERR);
FLASH_Erase_Sector(FLASH_SECTOR_3, VOLTAGE_RANGE_3);
uint8_t data = 'A';
if (HAL_FLASH_Program(TYPEPROGRAM_BYTE, start_address, data) != HAL_OK) {
    HAL_FLASH_Lock();
    return;
HAL_FLASH_Lock();
Thanks for your help.
