My I2C sensor and my embedded processor do not agree on the logic level. So I need a level shifter. Normally I would put a pair of pull-up resistors on the SDA/SCL lines. With the level shifter in the middle, do I need to provide pull-up resistors on both side? Or can it be either side?
    \$\begingroup\$ Depends on the shifter. What implementation are you using? \$\endgroup\$ – Samuel Nov 17 '15 at 23:31
  • \$\begingroup\$ I am using TI's txs0104e - ti.com/lit/ds/symlink/txs0104e.pdf \$\endgroup\$ – Adam Lee Nov 17 '15 at 23:34
    \$\begingroup\$ Reading the datasheet you supplied you'll see that device has 10kΩ pullup resistors integrated into it. You don't need to add any. \$\endgroup\$ – Samuel Nov 17 '15 at 23:41
    \$\begingroup\$ thanks. You can post your comment as an answer and I will vote for it! \$\endgroup\$ – Adam Lee Nov 17 '15 at 23:45
6
Neither side, in this case.
For other implementations, it may be required to add a pullup to one or both sides. Always read the datasheet, the answers are usually there.
