-1
I'm trying to make sure I have it wired up properly, because I am seeing very odd outputs from my DOUT (MISO) pin and I think it may be connected to my wiring. On a rare occasion I get a good set of pulses, but sometimes I get a pulse or two (more often none) and then it goes high and slowly trickles down.. but not nice and smooth like a capacitor discharging, its rough and jagged.. almost like slanted steps, or sometimes it looks like there are pulses in there, but very small.
Here is my wiring:
SCLK -> SCLK
CS -> SS
MCLKIN -> CMOS CLK @ 12MHz
MCLKOUT -> OPEN
RESET -> 5V
AVdd -> 5V
AINCOMM/P0 -> OPEN (IS THIS CORRECT?)
SYNC/P1 -> OPEN (IS THIS CORRECT?)
AIN0-7 -> OPEN EXCEPT AIN7 CONNECTED TO SIGNAL
MUXOUT(+) -> ADCIN(+)
MUXOUT(-) -> ADCIN(-)
REFIN(+) -> 2.5V (WELL 2.38V, I'm driving it from a 5V source with a resistor divider but its consuming a lot of current so I had to adjust from using 100kohms to 1kohms.. don't know if this could be part of the problem, datasheet states it only consumes 400uA?)
AGND -> GND
RDY -> ISR triggered on an inverted rising edge
DOUT -> MISO
DIN -> MOSI
DVdd -> 5V
DGNG -> GND
are these correct? I used this datasheet to wire it up:
http://www.analog.com/media/en/technical-documentation/data-sheets/AD7738.pdf
I really need this working.. it almost seems as if I have either not connected something properly, or my MCU is messing up.. but I don't think thats the case since its worked fine until now.
Also the RDY signal seems to work when its supposed to.
thanks,
scarlson
Update: added o-scope pictures and tried tying P1 both high and low with same result.
SCLK(teal) DIN(blue) DOUT(pink) SS(yellow) request for data
initial setup
    \$\begingroup\$ Schematic, oscilloscope screenshots, code, data would make you question clearer. Verbal descriptions aren't particularly useful. \$\endgroup\$ – Nick Alexeev Nov 18 '15 at 19:57
  • \$\begingroup\$ I will upload a o-scope screenshots tonight, and anything else pertinent. \$\endgroup\$ – scarlso9 Nov 18 '15 at 20:00
  • \$\begingroup\$ Datasheet p.7, pin P1 "When configured as an input, should be tied high or low". What are you writing to the I/O port register? ... REFIN, if noisy, might affect accuracy but shouldn't affect basic operation. \$\endgroup\$ – Brian Drummond Nov 18 '15 at 20:09
  • \$\begingroup\$ ..I think that may be part of my confusion. I don't understand what I should be doing with P1 or P0.. I am writing 0x01 to enable writing to the I/O port register and then I am writing 0xF0 to configure the port register. \$\endgroup\$ – scarlso9 Nov 18 '15 at 21:23
  • \$\begingroup\$ Could it be my chip is fried? I don't have another to test, but I would surprised if I did anything to damage it unless my pin configuration above is wrong.. \$\endgroup\$ – scarlso9 Nov 19 '15 at 1:01
For anyone that has a similar question, I was not sending 0x00 so my ss line was never going low so the MISO (DOUT) was never given a chance to send anything. one thing that does bother me however, is the discharge that DOUT experiences, although I am still getting the correct values it seems this is just how it works.
Also specific to this chip I grounded AINCOMM/P0 and SYNC/P1, which seems to work, AINCOMM is the analog reference voltage when the ADC is configured in single ended mode. SYNC/P1 is just tied High or Low, in my case I decided (arbitrarily) to tie it to 0.
Hope this helps someone out!
-scarlson
