I need assistance to understand why conducted emission test performed by one of our Customers using our Filter failed at low frequency of 205KHz.
The filter is a planar capacitive filter of 47K±20% pF which has an insertion loss of less than 10dB at 300KHz. The actual capactive value of the filter is on the higher side at 55 - 56KpF.
As seen in the graphs, the conducted emissions are going high only on the negative side of the battery. Why could this be so? I don't have much detail on the Customer layout or their test setup. And I'm not sure they are much willing to share too much detail on the same.
However could potential causes for this occurrence be identified with which we could discuss with Customer for a resolution.
