Sorry if this is not a question in the classical sense of stack exchange.
What is the cap that locks the wires called in the attached picture? I've not been able to identifying them with a fair bit of googling. Posting here as last resort.
Many thanks.
  • \$\begingroup\$ looks a bit like one segment of a chocolate block. \$\endgroup\$
    – Icy
    Nov 19 '15 at 10:21
    \$\begingroup\$ Looks like audiophile "special" zero-ohm silver-plated multi-strand pointless cable to me so I bet those plastic things are going to be expensive in order to ensure the audio distortion remains below 1 part per billion. \$\endgroup\$
    Nov 19 '15 at 10:24
  • \$\begingroup\$ Screw terminals on stranded cables without ferrules, what a travesty. \$\endgroup\$
    – venny
    Nov 19 '15 at 19:10
  • \$\begingroup\$ @Andyaka No way, this is generic chinese PVC speaker cable. \$\endgroup\$
    – venny
    Nov 19 '15 at 19:14
This is a single screw terminal block
http://www.radioparts.com.au/product/43322001/tbl2001-each-single-screw-terminal-block-32amp-450v-max#.Vk2jd3bhD0M
Also:
http://wholesaler.alibaba.com/product-detail/Australian-35A-6MM2-Single-Screw-terminal_952568246.html?spm=a2700.7724857.29.156.HeJqgZ
  • \$\begingroup\$ Isn't clamping several cables under one screw considered bad practice? (Maybe that should be an own question?) \$\endgroup\$
    – Arsenal
    Nov 19 '15 at 10:59
  • \$\begingroup\$ It's often done in light fittings, and other domestic electric circuits, good practice or not. \$\endgroup\$
    – Icy
    Nov 19 '15 at 11:02
  • \$\begingroup\$ Thanks a lot! In that picture, the terminals are being used to connect mains to a parallel circuit of light bulbs. \$\endgroup\$
    – Chris
    Nov 19 '15 at 11:23
